Wet passenger footwell
Hi all,
My passenger foot well is wet :( It seems to be coming in along the door seal as that's wet too (I've since noticed after sealing up my pollen filter assuming thats where it was coming in!
I've checked the drain in the door and that's clear... so I was wondering what else could cause it? possibly an open air drain? or is my door seal just fucked? lol
  • Replies 8
  • Views 2k
i think mines coming in the pollen filter how did you seal yours up??
Just used silicon to seal up the housing mate
Did you push anything down the drain from sunroof/open roof at roof of car down the pillar to clear the drain?
if you did you more than likely disconnected teh drainage pipe from roof,!
this happened me! just a tricky job fetching it back up if this is problem? youll find thso out if you peel back you are roof lining a tiny bit !
Might be irrelevant but said id throw it out there!
Gav
no, where are the open air drainage ducts located?
i don't think there is any drains on the open air roof from memory panda!
i am trying to think when my heaing was out what it looked like i am sure there isnt...
normal sunroof ones would simply be running from the corners of the opening.
check the seal is tight into the corners of the doors as this is where they tend to lift/leak
you tryed your heater matrix ??
Could be that
hope this helps
J
its only when it rains :(
new door rubbers, still same :(
