roller paint job?
as above, i will be painting my car in a few weeks, not decided on a color buts its gonna be some sort matte.
black
yellow
red
or whatever i come across...
I've painted cars before with cans, so iam confident i will do a decent job. but regardless...
if i was to roller it would i need to flat it after or anything? and would it have better resualts than a rattle can? i just want to know what there is to know about roller paint a car because I've never done one lol
dan
  • Views 1.7k
Its been done with gloss to good effect,once flatted and polished its claimed indifferent to spray.
There's a topic somewhere here on it,and pictures in said topic of a shiny blue mini - you should search it either in the topic search or the google one.
rollering seems like a pretty sick idea.. i read a thread on a hot rod forum about a guy who done a really good job. he used rustoleum paint thinned out and rollered on, and to apply it he didnt use a normal roller but something like a modelling roller? or something.. it was quite harder and smoother than a normal roller anyway
the advantages seem to be that its cheap, wont kill you (two pack) and you can do it on the drive
rollering can come out nice , but its lots of sanding between multiple coats , dont just think you will roller on one coat and walk away
rolledon.com has some pics/info
i've seen that too and when done properly seems like it can look the tits..
on the other hand i had a mk3 golf that had been rollered with matt black and it looked shit, the finish was rougher than a badgers arse and it was flaking off all over the place.
No worse than most rattle canned cars I've seen then lol
Applying paint with a roller is as good or bad as any other method. The advantage to roller painting and brush painting is that you don't get overspray, the disadvantage is the extra time.
If you're short on space and cash but rich in time, rollering can be a good option. Depending on the paint, the advice that seems to be most common is to use a good quality gloss roller, make sure the paint is thin enough and go for it. Many light coats are better than one heavy coat and taking time to flat out the paint between coats should give you a very good finish.
I'm currently painting my car with coach enamel and a brush and while it's taken me some time to get the hang of it, I actually prefer it to spray painting. I'm using less paint, making less mess and can paint pretty much anywhere since it's such low odour. Drying times are longer than spray painting (though matt and satin paint does tend to dry faster than gloss) and preparation of the panels is massively important for a smooth finish.
Since the paint is so cheap, it's easy enough to slap some on a large panel like the bonnet to get the hang of it and, if you hate it, you can strip it back easily enough. To avoid flaking, be sure to key back all the original paint first. Flaking happens when the paint layers haven't bonded together properly and a coarse finish will be from the painter using an emulsion roller which isn't as dense a foam/rubber/fleece as a gloss roller.
Edited by Angyl
