mk2 Coupe S - Sold
Regrettably having to sell the polo as I need a much bigger car for work :( Have done quite a bit of work on this and is a great car to drive, get lots of compliments wherever I go.
Year/Reg: 1987 D35 KYB
Mileage: 118k Will go up slightly as I'm still using it
MOT: Sometime in December
Tax: December 2010
Good Bits -
Exterior/Chassis:
Lowered 80/60mm on PhilJ coil/damper kit. Just had new top mounts put on, tracking was done aswell.
Genuine BBS Mahles 13x6 wrapped in 165/55's. The tyres were new less than 2000 miles ago, wheels had a quick refurb before the tyres were put on. New bolts aswell.
Rear wheels spaced out 10mm each side using high quality blocks between the stub axle and rear beam. Alot better than the normal spacers, easier to change wheels and does not wear out wheel bearings.
Rear wheel bearings replaced less than 2000 miles ago.
Rear drum cylinders replaced less than 2000 miles ago. All brake fluid was also replaced with new Dot4
Derby lights and grill. Not hugely easy to find these, specially with the lights in such great condition.
Rear wiper has been removed, it will all come with it though.
Aero wipers
Everything else exterior wise is standard.
Engine/Exhaust:
GT head/cam and block. Block was hammerited black before it was put in.
GK inlet manifold. Again not the easiest things to get.
Webber DMTL carb, manual choke. Has a genuine VW choke cable to fits in with the dash perfectly.
Still running all the original mk2 ignition system.
Facet electric fuel pump that has been hidden away in the skuttle tray.
8P gearbox, clutch was still good when engine was changed over.
Exhaust has had the middle box removed and just has a back box for clearance. Barely ever touches the ground, sounds alright aswell.
The cambelt and water pump on the GT were changed shortly before I got it, I've had it barely anytime. Not totally sure on the mileage of it but it runs very sweet, doesn't use any oil. Oil and filter were also replaced less than 500 miles ago.
Haven't had it rolling roaded but feels like a good powerful engine with the webber and GK inlet. Loves to rev and will happily go right to the end of the rev counter. My original plan was to add a 4 branch manifold and GT gearbox which would would finish it off perfectly and be pretty quick.
I also have a windscreen washer fluid bottle that goes in the boot so the one in the front can be removed to give a cleaner bay. I haven't had a chance to fit it yet but will come with the car.
Interior:
Recaro front seats, not sure what they were originally from. The original seat runner have been welded on but sit a lot lot lower than standard. Gives IMO a nice driving position. Unfortunately the cloth on the seats isn't great condition, but the foam is near perfect which is the more important bit so ideal for a quick and easy retrim.
Mountney leather steering wheel and boss. Very small, great fun round twisty roads.
Leather gearknob
Has some Sony Xplod component speakers in the rear parcel, previous owner did this. All original speakers are still in the car though.
Not so good bits -
The worst bit is basically parts of the bodywork, being the passengers front wing, which ideally needs replacing as it has a rust hole in the bottom corner. The bonnet has obviously had the passenger corner resprayed but not blended in very well. Areas of primer as beginning to show in the roof, obviously from being previously over T-cutted! There is also a scratch in the roof that has gone down to primer.
A couple of dents and a couple of minor surface rust spots, which are to be expected of a car this old.
The fuel gauge and temp gauge don't seem to work properly. The temperature gauge is intermittent, the engine never over heats so isn't too much of a concern. And the fuel gauge will only read just above half way when the tank is full. I haven't really bothered looking into this problem and just got used to it.
Exhaust occasionally knocks on the rear beam, which is due to where is has been lifted up so high to avoid hitting the ground.
The alternator appears to be making a noise as if the bearings are slowly on their way out. Still charges the battery up fine though.
Overall its a great car that gets lots of looks and compliments. Lots of fun to drive, and mechanically pretty good. The only thing that really lets it down are the areas of the bodywork mentioned, which could easily be fixed with a trip to the scrappies.
All the spares I've got, like original grill, will also be thrown in.
Has been raining most of the weekend so not been able to clean it and get some pics, so here and some older ones.
Price: £850 ono
Edited by goose
  • Replies 33
  • Views 2k
Gutted you're selling it dudee.
Good luck though..
Want to buy a polo? xd
I know, I'm gutted aswell. :( Needs must though!
And nah I'm good with the polo's :lol:
Hi I'm based in Bristol and interested! Any chance you could send me a pm with your number so I could have a look at it sometime in the next week?
many thanks, Jack
Pm'd you jack.
New price of £780, and I'll chuck in some VWII calipers with new sliders and bolts and new discs and pads aswell.
i will give you 600 cash mate :)
swaps for my 6n i keep my wheels let me no cheers
Sorry shaun, I'm after a Land Rover as my next car.
I have sent you a pm danny
Alright mate been lookin through you pics and so on just wondering if u would take 700 cash on collection
gimmie a ring 07791656516 :-D
straight swap for a mk3?
Nah sorry, not after any swaps! Already have my next thing in the pipeline.
Dropping the price a bit to £750, or £700 without the derby lights and grill
Will consider offers.
ill get back to you if my car sells soon enough
Okay mate, it's still here. I will be using it hopefully until the weekend and then it won't be needed and taken off the road ready for a buyer.
ok mate , do you reckon the car would be able to hack somerset to birmigham? cause id have to come a fair way to collect it likee
Yea would do it easily, I short while ago did Somerset to Leicester and back in a day and it didn't skip a beat, was perfect.
would you sell the mahles seperately?
No sorry mate, ideally want to sell it as it stands.
Not driving this anymore so ready for someone to come buy it :-p
satill waiting for my car to sell buddy. shouldnt be long haha
£700 with derby lights and grill? If so ill advertise mine for £700 so it sells quicker.
pm'd you jake
New lower price of £700 with derby front end, or £650 with original front end. Really need this gone now as I need the monies!
Also forgot to mention that I have a whole folder full of history for it from previous owner and lots of receipts for bits I have got for it.
