Rear Coilovers - Helper Springs
If i have the helper springs in lowered at 70-80ish would it have more give in them than having it lowered about 70-80 without them in?
Would taking them out be firmer, less movement?
Thanks, Pete
  • Views 837
helpers dont do anything when the cars on the ground,
they are just there to keep the main spring in place when u jack up the car,
although people do remove them as it give about another 20mm of lowness :)
hope that helps
Willl be removing mine on the front sooon as they are just not needed and i wanna go lower :D
