ergent help .. how to remove front seats from polo 6n?
anyone help quick
thanks
  • Views 3.1k
Some bolts probably, maybe even star bolts
either a ten mil spanner, or just the quick release clips?
and it's spelt urgent.
10mill spanner and a alan key but alan key isnt really needed if you dont have size! as it will still undo the bolt!
its held on with one 10mill bolt!!
this bolt is at front of seat in the middle !
then once this bolt is undone, sit on the seat and slide seat all the way back, it will come off the rails then at back and just lift out! easiest job in the world!!
couldnt believe was a 10mill bolt thats all!
Hope i explained in a way u understand!
Gavin
gavs right like,
you might have to remove black plastic covers to actually get the seats out thou!
gavs right like,
what covers? along rails? if so they will just click off when you sit on seat and push it right back till it frops at rear to ground! :)
had to do it only today for a mate lol he bent the rear back of seat so chagned this off a spare i had!
Simple job hope you get it sorted! :)
