I Can't See!
I'm having a bit of trouble with my windscreen and am just wondering whether this is common with a 6n polo.....
My windscreen won't stop steaming up, as soon as i start the engine it steams up slightly but then gets worse as i am driving, especially in the dark when lights are shining on it.
I have tried opening my windows, putting the blower on it on all temperatures and i am now running out of ideas what to do.
I need to be able to see when i am driving obviously so any help or tips will be much appreciated.
  • Replies 23
  • Views 2.2k
I just leave the heaters on at full blast and it will gradually go, better then opening and closing the windows every 5 mins.
Sounds like condensation...do you have a water leak,wet floors?
Edited by buster.g40
Perhaps a new pollen filter may help.
Hot or cold???
Sounds like condesation...do you have a water leak,wet floors?
No water anywhere else as far as i can see.....
what is that???? lol And is it expensive to get done???
it's a filter that goes under the scuttle panel costs a few quid
Oh rite, i will consider that then........
thanks
If it's blocked then you won't get a good airflow. Check your carpets aren't wet.
Check the boot for a water leak too....
Ok then.........i haven't noticed anything in the car being wet, however i will double check this.
Everything seems to be in order tbh, the blowers work well, heat up quickly etc.
1st time today i got in my car at 4pm and soon as i got in my Glass's steamed up, still cant figure out where my leak is from as it runs down the side speak of my passenger door :(
definitely your pollen filter
Ok well, i will try figure out what these bits are u lot are referring to lol.
I'm a female who knows nothing about cars after all lol.
Then i have to find someone to fit it too lol.
Thanks for all you are help tho. :-)
Hot or cold???
HOT, takes time but once its gone, it gone for the whole journey.
In the mean time get some anti-fog treatment
too much dogging i reckon...
The pollen filter is outside under the passenger side scuttle tray (Black piece of plastic near the wipers under the windscreen).
It's just held on with a few clips and once it's off it right infornt of you.
To change it you don't need any tools either, it's just clipped in.
Pollen filter = kinda speaks for itself really lmao :)
Sorry I'm not any help at all :):)
Get a dehumidifying log thing to put in your car to remove the moisture
Well.....not really tbh, especially if you know nothing about cars except how to drive them. :p
I shall attempt to help.
Follow what he said and you can't go wrong..
It looks like this
And goes in here
(that's a Range Rover, but you get the idea)
Make sure you put it in the right way round
Good luck
Thank you very much, that will really help me. :-)
