Anyone succeeded in a DIY roof wrap?
Anyone performed a roof wrap or even a bonnet wrap on there car? how easy is it to apply and hows the finish?
..may have a go, tried window tinting which failed but a roof may be easier specially with a viynl :-)
cheers
  • Replies 10
  • Views 1.7k
hiya mate i just attemped doing my roof consdering i have sprayed my car myself i didnt think it would be hard but it was and we couldent got the bubles out and it looked terible so I'm just going to spray my roof now.
look at my build thread for the pics ...http://www.clubpolo.co.uk/forum/index.php?showtopic=185279&st=50&start=50
Edited by jamiet2
wouldnt think it would be to hard ??
heat gun and alot of time
regarding the tinted windows......iv done these loads and it is possible to get it just as good quality as doing professionally.
What most people dont realise is to completly soak both the window and the tint in soapy water, with a spray gun as you peel the backing off, dont peel it all off them spray it, spray it as you peel. make sure you have lots of tissue paper available though to hand. and a bank card. (i find a shell card is best due to the curved corner).
wrap a bit of tissue over the edge of the card as you gently push from middle outwards.
All bubbles will comes out. and can get a perfect finish this way.
Experiances suggest not to push too hard with the card, you can and will tear it.
Once its all dried, its stuck on good and solid. :):)
easy peasy. did my old 9n2 windows in about 5 mins each window. it really doesnt need to be hard.
good luck.
preparation is the key to applying vinyl
if you are doing the roof then just cover it in water, soap can cause more trouble, and just normal water will do the job of allowing it to be positioned, then you squeegee the water out, edges can be a pain, depends on the roof, i would not use a heat gun, will again cause more problems.
have a look on ebay for a foam squegee, makes applying much easier
As above but i use about 3-4 drops of washing up liquid in a 1l spray bottle and soak both the vinyl and roof.
Cut it roughly to the shape of your roof,
Take it off,
Spray loads of water on the roof
Put the vinyl sheet on the roof upside down - vinyl part face down,
Peel the whole of the backing paper off spraying the sticky side of the vinyl as you go along,
With a mate both grab the drivers side then lift it off towards the passenger side using step ladders or something and lift it off the car until the vinyl is hanging
Pick up the hanging corners then lift it back on the roof,
Drop the vinyl in place and let the middle stick to the rood but pull it fairly tight,
Now run a felt squeegee (off ebay) from the middle down the front and back along the centre of the roof,
Then in a union jack style squeeze out the water,
If you think its going to crease, you can lift the vinyl of a few times and it will be ok,
Then to tuck it into corners/sunroofs/roof rails etc use a heatgun to help it stick,
Now just trim the exess with a scalple or something and your done!
Hope that helps :)
My old car
I bought a vinyl sticker off ebay a few weeks back and it came with all the instructions listed above but one other helpful hint, just grab a small pin and pop the air bubbles with a tiny hole. incidently the sticker i bought stuck with no problems!
i had a union jack vinyl for the roof of my mini,didnt chance to put it on so sold with the car 10 years back...
what a fool i was :-(
My friend did the roof of his pug 106.
Right may have ago the :thumbsup: n and have another ago at my tints with your advice :)
cheers
i have done this many a time, its easy.... once you have the hang of it. for starters dont buy crappy ebay vinyl if you can make sure you get 3m or avery 900 as these are the best quality they stretch alot and are quite thick. its alot easier if you have a friend helping. all i can say is go for it, worst comes to worst rip it off and start again. and for the record i used to work at Totally Dynamic, any more questions feel free to pm me.
