New Polo Owner - Advice on fixes & parts
Hi,
I'm new to the forum - I've just bought a Polo Coupe I think it's a MK3. I bought it because I need a smaller car than my Alfa 166 (which I have loved) because my old car doesn't fit on my drive since moving to the countryside and I don't need such a big car any more.
I really like the Polo Coupe and hope it's going to be the ideal car for my new countryside life - cheap to run and maintain. It's got FSH which is pretty impressive for such an old car so hopefully that's a good sign at least I know everything that's been done to it. As far as I can see the changes I need to make are fairly minor. I could do with some help & advice on how best to get cheap parts & in particular the following:
- the aerial is bent and a bit rusty - can I find a replacement easily & should it be easy to fit?
- there are a few rust patches - what should I do about these - preseumably I need to treat them somehow?
- The passengers door lock nob thingy has snapped - Is that something I could find/replace?
- The wheels are really nice allowys with VW signs in the middle but one VW sign is missing - where could I find one of those?
any help and advice greatly appreciated!!
thanks,
Alan
  • Replies 18
  • Views 2.2k
Welcome to the forum :)
Regarding your questions;
I cant help with the aerial, the last time i took one out, i cut it off :lol:
Rust, I'm assuming its the bottom of the back arches/sill overs, rust treatment is fairly easy, get all the rusty bits with a wire brush of some sort (drill attachment/handheld etc), then whack some hammerite on if your not bothered about the looks, or prime and paint
Not sure what you mean by door lock nob thingy
Pictures would help with sourcing a new center cap
Other common things with MK3s that I'm aware of, the bottoms of the doors rust, the battery tray rusts, they like headgaskets, the exhaust hangers rust and fall off and a minor one, the bumpers do sag occasionally
Enjoy :)
Enjoy :)
Thanks, that's great advice - now you mention it the bumpers are sagging a little - is there anything I can do about that?
Other than the rust spot in question (just under the protective strip on the passenger door) the car's in very good condition so I do care about looks. I'll scrape away the rust and look at fixing it - I'm assuming if I do care about the looks then I need to use something other than hammerite and I need to put something like anti-corrosion or something before repainting. I learned from the manual where to find out the VW code for the colour.
The door nob thingy is the bit you pull up from the inside to let people into the car - except I can't on my passenger's side because it's snapped off.
I'll get a picture posted for the wheels then - they look really nice but one's missing a red VW sign in the middle. I need to find a digital camera and the leads etc to upload the photos but will do that tomorrow.
Another couple of 'interesting' things I noticed when I picked the car up today:
I filled the tank full as I have with my other (newer) cars by sticking the petrol nozzle into the fuel tank, squeezig the trigger and waiting until it automatically stopped when the tank was full. It did stop but slightly too late - it kind of splashed out a little and I got petrol everywhere! Is that normal. Either these cars weren't really made for modern fuel pumps or mine has a small problem - nothing major of course, having seen how much petrol the car takes I could just make sure I stop before the car is completely full or start taking it very slowly after about £38 worth (I reached £45 pounds of petrol from an empty tank before spilling it everywhere).
When I put the petrol cap back the key seemed ineffective - i.e. I think I could twist the cap off and put it back on whether I had the key or not - I'm still not convinced if this is actually a problem or it's just a fiddly technique I'm not used to. Next time I tried the key did seem to do something, I haven't played with it too much yet because of petrol smell for now but will have another look tomorrow.
Third petrol cap issue - the door to the petrol cap became floppy and stayed open instead of snapping shut. On a closer look it's just a very basic & flimsy mechanism which I could kind of bend back into a little slot and enabled me to snap the door shut again. Is that normal? Result is I just need to open the petrol cap door gently.
The wind seems to be getting in somewhere around the passenger door - at least it makes that kind of noise, but I can't see anything anywhere, can't feel any draught and the door looks well shut - it just makes a whistling noise when I'm driving. Any ideas? I suppose I need to look at the seals or could it be something else?
Sorry this is becoming quite a long post but I do really really appreciate any help & advice,
thanks,
Alan
Oh the door pin, it twists of after about a million turns, spares are easily found, the ones off a mk2 golf fit if that's easier to find than a polo,
The petrol tank thing could be the filler neck playing up, put your head in the o/s rear arch and have a nosey at it, it's another common rust spot
The filler cap is probably just the nack of using it, I couldn't sus mine out for about 10mins
The wind noise could be a perished door seal, or the problem I had was someone had bent the door back, letting water in
I can't help with the filler door, I've never dealt with this before
Hope you sort it out mate :)
Thanks you so much again!!
Well I've had a nightmare today.
After leaving the car parked for it's first night, I noticed in the morning a petrol leak. You are right about the filler neck - it is rotten about half way up which I guess means it would only leak when more than a certain amount in the tank. Anyways, it worried me so I took it to a garage for advice. Whilst there I noticed an oil leak from under the head gasket and a water leak from the radiator as well. The mechanic told me the previous owner had left the water tank cap loose either because he was constantly filling up water for the radiator and forgot to tighten it properly or perhaps he knew of a more serious problem with the head gasket and left the water tank cap loose to relieve the pressure. He told me £600 to replace the head gasket!!!
I bought some radweld and it seems to have fixed the radiator leak for now - also I think the head gasket is OK as I checked the rubber tube and it is soft, the car doesn't seem to be ovverheating after I tightened the cap so I guess the radweld has done the trick for now.
Just when I was coming to terms with these problems the seller hadn't told me anything about, as I was driving along the exhaust fell off!!
The guy who sold me the car did seem really honest and showed me a full service history (which included a new exhaust but I guess not the middle bit which is where it fell off) but I am now worried about what other surprises I will have and if he knew about these problems and has basicaly conned me.
A neighbour who knows a little about cars has reassured me quite a bit before I start chasing the seller to get him to give me my money back - he reckons I've just been a little unlucky on the first day, these things happen and the car's OK really.
I'm just not sure what to do now - my theory was that this should be a nice cheap car to keep and maintain but am I just being naiive?
I really like it, it seems to drive well (before the exhaust fell off) but I'm worried in case it starts just being one problem after another and then I end up with a knackered car I've spent loads of money on that I then can't get rid of? Am I overreacting? Can you reassure me?
Any idea how much I should be paying for the middle and flexible connector sections of the exhaust and how much I should expect to pay a garage to get these fitted (assuming I can't work out how to fit them myself)? The parts I need are VW70D & VW111Y
Please save me from depression ;)
These cars go on forever! Just bare with it! It's the exhaust and I'm sure you can understand that it's not stainless so it's not going to last forever,
I just spent £360 for a whole new exhasut system and the £400 for. New ppp exhaust manifold, and made a mess when fitting the manifold wich has led to the car being at the garage for the last 1 month and 2 weeks,
All the parts that you seem to be having problems with just seems normal, radiators leak over time, exhausts rust, body work rusts, it's normal and happens on the majority of cars.
As for the whistle you got the same happend on mine and it was the drivers side air vent leaking a slight bit of air fro
Were it wasn't sealed properly with the factory foam.
Takes about 5mins to fix.
I bout my mk G40 and had it for about 2 weeks and let my money burn a whole In my pocket and I started replacing things whilst not knowing what I'm doing......hence why it's In the garage lol!
Thanks - that's really reassuring and very much appreciated - for the moment I'm going to stick with it.
Though the idea was to save money with this car, not spend it.
It seems to be a labour of love for most people looking after old cars.
I'm still not sure if once I repair these things that means the main things are done so should be OK, or I'm being really naiive and the car is going to keep costing me and costing me as different bits and bobs rust, fall off, stop working etc.
Looks like I have a lot to learn !! ;)
Yea it does seem that way for little while to be honest, you will get it sorted in the end and you'll appreciate the car more,
I'll never get rid of my G40 now if spent that much money on the car, near 5k!!! Even when I have my M3 I'll still keep the polo as i would of spent that much money that I would of just made a mega loss wich is the problem with modding, when it's all done it'll last for a long time and there such a good strong engine and there easy to work on too wich is a massive help
To be fair the exhaust are pretty dire on a mk3 Polo. They aren't the best design and do tend to drop off. Usually the biggest problem is the rubbers being shot. I went through all sorts of rubbers, random ones we had down the unit, halfords, local auto place and in the end I got a set from VW and since then never had a problem. They aren't even that expensive. There like 99p from Halfords and about £1.79 from Volkswagen. Bit more expensive but they seem to do a better job.
stick with it - I bought a mk3 oct 08 because the car I had before had fell apart and I was not as paitent with you with my mk3
It had an alternator problem, head gasket went after a week of ownership and did the same petrol leak and water leak yours did and after doing not even 1000 miles in it I sold it in Jan 09 because I was so angry with it and couldnt bear to look at it any more.
If I'd of had time/money I would of sorted it out to get it into a nice little car but I didnt and kind of regret it now!
Thanks - I really appreciate it. The thing I'm most worried about is rust so I will get the exhaust and petrol neck sorted then I think I'll take it to a local bodyshop and ask him to give it a once-over and take care of any rust spots.
When you say rubbers do you mean the kind of rubber rings that the exhaust is hung onto the chassis with? Mine also had one of those plastic cable tie type things on the back which seemed quite effective (before I had to cut it off to take the exhaust off completely so I could carry it home). I will look out for some rubbers from VW then, sounds like a good investment.
Presumably (once I fix it) aside from any rust problems, the better the exhaust is attached both front and back, the longer it should last & the better for the car - any other advice on what I should consider when fixing it? Any idea how much I should be paying for a replacement (middle and front/flexible pipe sections VW70D & I think VW111Y) & where I can get the best deal?
Many thanks - your advice is very much appreciated!!
Alan
That reassures me a lot. Can you remember how much it cost you to get the various things fixed? I am sure I will have to replace the head gasket on this one soon. I know exactly what you mean I loved my new car until my nightmare first day & now I don't really want to look at it - it doesn't look good with the exhaust inside instead of underneath it!! I need to get it fixed but I'm struggling to find the parts - part of my nightmare day involved a last minute rush to find a VW salvage place around derby with our mega loud engine & exhaust in the car with us - we found 3 but they had all cosed down so we went home with our tail between the seats :-(
Hi there
In response to your earlier post
the aerial isnt too bad to replace. You can either get a second hand one off here if you want originality, or do what I did and by a universal fit wing aerial from Halfords, 7 quid!. To replace it you have to jack the car up, remove the front left wheel and then remove the plastic panel inside the wheel arch. The aerial is held onto a little bracket, and to remove it you unscrew the silver trim at the bottom of the aerial (the bottom of what you see on the actual car!) Reconecting the new one can be a bit tricky though, as you have to run wires round to behind the radio and that can be uite awkward to find!
Golf. You can have the pair for 2 quid posted if you want :-p
My petrol tank rusted through too (I find this out the morning after I put £35 of petrol in, and wake up with it sinking into my drive!) It cost a bit to get replaced, but as I see it now itll last another 18 years til it has to be looked at again :-D
Hope my rambalings are of use to you!
Rich
Hi there
Rich
Rich,
many thanks for the advice & the offer for the door pins.
I have actually got one from someone locally but thanks a lot for the offer,
cheers,
Alan
the way i feel today 5 litres of petrol and a match should fix it quite well
my head gasket and fuel tank and just about every other part on mine was broken when i got mine but its very easy to do these jobs on your own just get stuck into a haynes manual you will be fine
I know what you mean!!
Your car looks like a saloon version of mine. Is it metallic blue?
scrap yard 8-)
