steering wheel clicking
last few days I've noticed that when i turn my steering wheel there is a slight click but it only happens every now and then has anyone else had this problem. I've got a 6n 1997 1.4 polo that hasnt been lowered had new wishbones a few months back.
any help would be great.
  • Views 1.6k
Hey mate, it could be the metal contact for the horn. Have a look in the gap between the wheel and the bit it's mounted too and you'll see a metal bit sticking out - try bending it a little with a screwdriver or something - mine did the same.
Could be the indicator self cancel, happened to mine and had to pikey fix it. Try indicating and then turning the wheel to cancel it and if it clicks. If its the same sound then thats what it is....
cheers for the replys guys ill give them a try in the morning. will be glad to get it sported as much as i like listening to my music loud its still annoying to hear it clicking or feel it clicking. :-)
My Mk3 has started to do the same lately. Some good tips above, so will try these also! Cheers.
is it from the wheel itself of just in the general area? it cold the universal joint gone dry?
of if its further down posibly a cv joint?
On our 6N2 it was actually the airbag slipring! A week later the airbag light was on and couldn't get rid of it.
Ended up changing the steering wheel and slip ring to get rid of it..
I had this same problem on my 97 6n. I think it was the horn contact as mentioned above. i sprayed a bit of wd40 in the gap between the steering wheel and the boss and its bin perfect ever since! :)
