how to take the front door cards off a polo 6n ?
hi everyone a couple of days ago i bought a polo 6n and i want change the speakers in the doors as 1 of them is blown but i cant figure out how to get the door card off as i cant find any screws holding it in place if anyone could help i would be very grateful cheers
  • Views 1.6k
If you're literally just changing the speaker, then you just pop off the speaker grill and unscrew the speaker
but if you're going to be doing anything more major the door card is attached via 2 screws under the grab handle (pop the cover off) and then there are just clips all the way around the outside, just need to pull on the door card to release these, also need to unscrew the door lock pin
ok mate cheers
they're hiding mate!! use a flat head scre driver and carefully prise off the plastic front of the handle on the door the main part (not the bit you pull to open the door) then there are two screws i think on there that you need to undo keep them safe
next unscrew your door pins just by hand, and starting at the top of the door card pull it off, its attached by clips so dont force it cos you dont want to break them.
once there all off you need to take out your mirror switches by the handle, they just pull out i used a flat head again to get em off, but be carefull not to break the clips again.
then lift the door card over the door pin and open the door so the handl fits through
easy!! just be really carefull and patient taking them off.
need any more help drom me a pm
hope it helps!! :-D
ok mate thanks alot il have a pop at it tmora
While we are on the subject ow hard is it 2 change the speakers in the dash is it a pain in the arse or quite easy? cheers
