Water in rear passenger footwell HELP!
my mate noticed the other day when u put pressure on the carpet water comes out so were would this be gettin in from?
would it be from underneath the car?
any help would be great thanks.
  • Views 1.2k
I have the same problem with my 6n when it rains and noticed the door also had water inside it. It's possible water drips into the car and runs to the rear carpets. Went through a deep puddle which didn't help things either. Check all rubber seals on the door and the seals on the roof, if you've got the same car. Also check underneath around the draining rubber grommets. Round in shape. Pain in the butt....
Had a similar problem in a friends polo, it was only when he pointed out his rear wiper washer was also not working that we realised where the problem was. Worth checking?
Edited by Petrified
ahhhhhhh! well my rear window washer jet isnt workin ether so wether theres a hole in the tube n it just filling the back of my car up?
will look more into this
cheers
Same thing happened to my rear washer, the tubing had come apart (theres two lengths with a join just by the rear passenger side.) Mine would have been wet but I didn't keep using it when it didn't work because i knew it would be pissing out somewhere.
Have you got standard rear lights? If not, check the units are well sealed if not that could easily let water in...
