Newby want to say Hi
Hi. Hope I put this in the right section. I have just bought a 2002 Polo 1.2 S. I have three kids who will all be 17 in a couple of weeks :shock: and we thought this would be a good car for them to learn on. Any tips on this cars quirks, known faults or just things to look out for, would be really appreciated. Oh and I would avoid High Wycombe for a while if i were you. :lol:
  • Views 882
Hello and welcome to clubpolo!
I'd say, the main fault with the 9n is the weak 1.2 engine.
Coilpacks are common (look out for a misfire, stuttering)
Timing chains are weak (I'd look at changing it before 50k and use the revised kit)
Also change the water pump, again my old one failed around 50k.
They're under powered, not terribly economical and not very reliable either.
On the chassis side, you've only really got console bushes and ARB bushes that wear out.
The console bushes are a terrible design (voided bush) they're supposed to be comfortable, however they just wear out quicker!
So when these go, replace with seat ibiza cupra ones, as they're solid and will last alot longer.
Other than that though, ideal for a learner, they're easy to drive and the panels are well built plus the front end is bolt on, so can be changed easily enough if there are any accidents!
welcome and hi and what he said lol
Oh err Maybe just a little worried now. Still could be worse.
Edited by Wingfield 3
