polo 1.6i16vG60
Hello polodrivers
My Name is Richard and I,m from the nederlands.
I drive A polo2 1.0L :-D daily for work ore go to the gym..
13inch RSL 8-)
Also i,m building a polo 2f 1.6i16v with a G60 charger :-D
for a friend we build a 6n2 1.6i16v with a big Garret turbo, i have post photo,s on this forum.
that is ready so now i can build my polo2f further..
the engine is fully rebuild with much stronger Components for the things i wanne do to it :-D
it,s a AJV engine from a polo gti limited..
1.6i 16v DOHC
it,s bored and honed to fit the 77mm wiseco pistons.
the crank is balanced with flywheel.
we have mounted H-profile rods from a 1.8 engine big block..
cnc machined the rods to make them fit the small block engine :-)
i have mounted a BMW e39 Intercooler so i can order some pipes and sleeves now..
the g60 charer i stil dont have, safe that for last..
i have a shitload of photo,s.
First i had the wrong info for the rods so i order some wrong sizes :x i wanne had that in hous but the plane go wrong unfortunately
the ajv rods are 139 i thought. the others are 144mm. to long...
so i had to order some other rods from a g60 en had to level the engine to make them fit..
  • Replies 32
  • Views 5.8k
I welded my own exhaust manifold
not my best welding but nobody see the wled,s wen i tape the exhaust with heatwrap.
that are the photo,s for now..
hope you like :)
Gr Richard
you ARE the man, man!
WOAH!
yummmmmmmmmm what inlet are you using one from a g60? nice custom downpipe dude awesome work the g60 charger mount the same as an eaton?
this was the box with 2 engines in it :-D
1 ARC and 1 AJV on his way to the rebuildingshop..
the enginebay
Its a golf 16V inlet welded on a polo gti plate 8-)
the throttle is from a G60, and the G60 charger go on a custom made mountingplate :-)
G40 atv gearbox
the hood can close :-)
bosch feulpump
Edited by richard16vg40
is this this?
looking good so far!
Hello Richard :thumbsup:
Looks good, but the intercooler will be below the bumper line? :smoke:
is this this?
that was my 16vG40 8-) same engine but with standart internals...
173bhp and 230nm torq :-)
@ yoof, yes i now but i wil hang the cooler on a better place wen i have ol the hoses.
i need to make some more room to put the intercooler further to the back!!
cut out some bits of the bumper bar..
Gr
Interesting stuff - more pics please !!
well there is a misfortune with the intake manifold :(
because it are 2 different intake bits that welded together and one of the chanels has 1 smal weld there became a hole :)
so the intake is gonna level and gets a thicker weld...
this is how it was!
and this is how it,s looking now :-)
the hole is also closed now 8-)
and all works close past each other
next thing to do is making al the hoses and tubing
That's mega haha and like your mk2 with rsl on :-)
Thanks :-D
the 16vG60 is waiting on a G60 supercharger :-) but i need to spare some money
if got too make a bracket four the injectionrail..
Wow mate you've got some skills! I also love how the mk2 sits on the little cults ;)
I wouldnt dare try and weld my own manifold! So hats off to you!
i love how rago this is lol..
This is what you call a rat look engine ;P
This is truly awesome, cant wait to see it finished 8-)
bumper+intercooler on his place :)
if bin busy with a ABU cilinderhead for rebuilding..
for a later projekt of my 1.0 turbo with abu head :biggrin:
and valve polishing
that is sick i love the manifold well made :) i bet it does like a train dont it?
  • 1 year later...
not straight :x must weld the exhaust a bit more to the head..
it takes a while but where getting there 8-)
Very cool 8-) Look forward to seeing this completed!
Ian.
