Swapping electric windows to manual
My driver`s side electric window has stopped working altogether. I`ve had somebody look at it but they were useless. The passenger one works fine. I don`t know what the problem is but I`m actually considering just removing the electric windows altogether because I can`t be asked to pay to get it all fixed, I can see it being expensive, labour, parts, vat
Is it possible to resort back to manual winders, if so how?
Edited by JonMilner
  • Views 961
it's very very possible.
The easiest and simplist way is to leave the wiring in, simply take out the electric mechs and replace them with manual ones, that way you can change back if you ever want.
The only serious drawback is you'll have to either make holes in your door cards for the winders and leave the elec switches in or buy new cards.
I'd suggest finding a competent mechanic or auto electrician first though, usual fault is the wiring in the door gromits, pop the rubber bit off and look for breaks/splits.
I`m going to ring my mate who is a tech at Seat and see if he is interested in having a look. I`ve already thought about the doorcards, If I do it I`ll get front doorcards from a non e/w mk5
How easy would it be to get hold of the non electric mechs?
I'd imagine somewhat cheap if you can find them, lower spec mk4 polo ones work too.
I threw a set a few months back so i don't think you'll struggle.
Try holding the key in lock when you open it, see if the window works.
It could also be the switch too. I drive everywhere with the windows down - even if it rains. And switches don't like the rain!
The internals got a little rusty, but it took less than 3 minutes to work out how they went together, get the contacts cleaned, and back together!
Check the wiring for splits (between the body and the door), and then check the switch. Can you control the passenger from the drivers side?
