Polo passenger footwell water leak :(
Hi chaps my names Adam, i have recently bought a `s` registration 5 door 16gl polo as a runabout whilst i get my (waits for slaiting) RS turbo fiesta ready for paint after restoring it, the polo is a very tidy car with a full respray and nice set of wheels.....is a tad high tho 8-) i have a couple of problems I'm hoping u can help me with:
I seem to get water leaking into the passenger footwell which i can assume it might have something to do with the pollen filter? (if it has one?) as i sorted my missus mk4 golf gti from doing this by changing it, but wanted to know is there anything else that causes it?
i also have a puff of smoke at start up and only on start up, it seems to have not been serviced for a while and i know its been ragged as i have just put a clutch in it when it was replaced in 08 :? but i only gave £50 for the car so cant be too fussy, is this another common problem or not?
Apart from that shes a cool little car, but I'm looking to give it to my mother-in-law once my cars in for paint next month so want it right for her :-p
Many thanks Statey
  • Views 1.3k
Water leak is probably pollen filter/heater area. Gets blocked with leaves etc, take the skuttle panel covers off, then clean it all out. At either side there are gutters which lead down into the front wheel wells to drain water, make sure these are both clear.
Never had the problem on mine, but when I took the skuttle panel covers off it was stacked to the brim full of leaves and shit.
Smoke could be valve stem seals? Worn rings? Just a cold engine? Mine smoked a little blue smoke if I booted it from cold, once warmed up and everything had tightened up it was fine!
Thought it might be the pollen filter :)
yes the smoke is only as u start it for the first time in the morning then its fine, will just keep an eye on that and see what happens :)
