Does any1 no any info about this mk3
Rite i have just bought this car and a was just wondering who had it before danno had it
  • Replies 26
  • Views 3.2k
Cant help but that looks mint :lol: whats the spec?
Its a canny enough car like it's got some sort of coilover setup it's stripped out with a 1.3 engine
God nos what the setup is like lol
I nearly bought this off a bloke called John up in durham, but got put off cos i did a check and the last time it apparently changed owners was in 1996 i think. Looking nice though, was up for a decent price aswell :(
How much was it up for
Why would this put you off?
Erm if i remember rightly mate it was up for 450?
Because it had only had 1 (or 2) previous owners prior to that, and having spoken to the guy it appeared it had had more. So I dunno, was my first polo that i nearly bought, I was easily put off! lol. I'll dig out the vic check later
Edited by Patttt
i beleave thay are mk1 golf struts and hubs
that's a mk1 golf set up, same as i have on mine although this looks like it was done a long time ago, although they look a bit sketchy tbh :?
both the steering arm and the hub mounting brackets look like they are home brew jobbie's, also those ain't the correct bolts by the look of it although even if they were the camber adjusting washer's they would have on them would be useless with those hub mounts. i can't understand why he didn't just use mk1 golf coilovers and add steering arms to them rather than make his own struts, it'd be interesting to see if he has even set the steering arms to the correct angle's or just put them where ever :?
the car looks bang on tho :thumbsup:
Edited by McLOVIN
I fancied buying it for the coilovers but I thought £700 was a bit much. Other than the coilovers and wheels its a stock mk3 so I didn't think I'd make my money back on it enough to warrant buying it just for the suspension. Seemed like a pretty tidy shell from the pics though. So in a way would have been a shame to bust it.
i'm guessing you hadn't seen them at that point? :lol:
the ball joint on the end of the steering arm just looks pure dangerous tbh :shock:
I'd be interested at looking at that steering trackrod. looks non vw. and as that is the side which costs £70 at vw it may be a way of renewing it cheaper.
get a photo of it for me please mate- I've got my thinking cap on
looks like a universal rose joint, with a bolt thru it.
rally design sell em for peanuts
A bought it just as a winter runner while ave got my passat off the road through the bad weather, it drivers like a minter like much better than my old mk3 goes round corners like it's on rails
:nod:
but you should really fit them with a dust cover or they wont last very long at all.
That steering arm fabrication looks pikey as hell, the material used for the arm is too thin, it already looks bent to me. I'd expect that to fail an MOT to be honest on the grounds of (from the suspension section, reasons for failure in the mot manual):
2. Deliberate modification which
significantly reduces the original strength, excessive corrosion, severe distortion, a fracture or an Inadequate repair of a load bearing member or its supporting structure or supporting panelling within 30cm of any sub-frame, spring or a suspension component mounting, that is, within a 'prescribed area', see Appendix C.
I'm also laughing at the random length bolts used, it almost looks like someone has cobbled that lot together with bits of scrap they found lying about in their garage.
Studs are OK though, I've converted mine to studs too, much easier for swapping wheels about with no disc screw and spacers:
note, I've converted my mk3 struts to coilovers but used the original steering arms which I'd carefully cut off and re welded back on lower down.
It's a winter runner if it fails a test which a dought it will it will get a dodgy test then al scrap it, simples a don't think the track rod is bent like the car drives straight
sticking dodgy mot on a car that is that bodged is fucking retarded tbh. as hayesey says it looks like it's been made out of scrap metal, this is a MAJOR part of your steering, can you imagine what would happen if that fails while you are driving it?
imagine if it went pop while you were hooning down a country road
i've used mk1 golf coilovers with the polo steering arms welded to them which had been carefully removed from the polo struts and opened up to fit the coilover. also we spent ages making sure that the angle of the steering arm was as it was originally on the polo, albeit with it lower down to keep the track rods at the right kind of angle when lowered
Its a mk3 polo they are horrid things do you really think am going to go on the back roads with it all this for is is summit to fuck up in the snow
yeah I made a jig to do mine which held the arm in place but used a piece of threaded bar to move the steering arm down. To be honest, it doesn't have to be mega accurate as you can dial out any slight difference by adjusting the tracking. It never really occurred to me to use mk1 golf stuff when I did these a couple of years ago.
you seem to be missing the point lol.
What people are saying is, it's dangerous how it is.
Dodgy MOT doesn't make it any less dangerous.
Just driving it in the snow doesn't make it any less dangerous.
It being a horrid thing, doesn't make it any less dangerous.
you not driving it on back roads, doesn't make it any less dangerous.
People aren't concerned because you'll destroy the car, people are concerned because you could stack the car into a family waiting at a bus stop.
Sure we've all paid the MOT tester a bit extra to look the other way on the emmissions test, to turn a blind eye to the de-cat pipe or maybe even to ignore the red reverse light because we've got german spec rear lights. But getting a dodgy MOT on a car that you have been told is dangerous, that's just asking for trouble.
i'd be suprised if you find an mot tester that will put a dodgy ticket on that tbh, after all it's their name on the ticket, their mot licence on the line and if they put a ticket on a car with this sort of defect and it had a bad acciedent because of it, it would also be their freedom on the line too.
Would someone like to enlighten me as to how that's dangerous?
It looks sturdy, well attached and reasonably well executed through the use of a spherical bearing?
If it looks "bent" then how are you to know that it wasn't fabricated that way as to align with the track rods correctly? And as for one bolt being too long, that's completely inconsequential,as it's long enough.
would be interesting to see people's reasoning.
for starters the ball joint is open to the eliments so as well as all sorts of shit being able to get into it there is also no way of keeping it lubed up. This will cause it to ware very quickly.
The steering arm, although sturdy looking is of a poor design and it doesn't matter how think the metal is that you use, if the design is shit it will leave the metal open to fateage (sp).
The bolt being too long may not be dangerous but it does highlight the way in which these were chucked together. If he couldn't be arsed to find the right size bolt for that part, did he go to the effort of fitting a suitible bolt to the steering arm ball joint that was designed to take the stresses that it will encounter, or did he as it looks just chuck any thing in that fitted the hole?
Maybe it is strong enough to do the job, but the question is looking at the was its been built and fitted, would you stake your's and your familys life on it? Because thats what it boils down too if it fails while your all in the car.
