fitting heated washer jets on mk3?
now then,
theres a lad on here selling some heated washer jets for a mk3 polo, anybody know how easy these will be to fit, like what to wire to what etcc? or anybody got a guide??
thanks,ben
  • Views 1.2k
they just push fit in-place of the old ones. then you need to build a loom to link them and take the feed from the white front fog plug, they then switch on when the for switch is in the middle or when the rears are on.
or use a ignition live feed so there on all the time when the engine is.
ahhrite, i dont know much about wiring but how easy would it be to put my own rocker switch in the dash and have it as an on/off jobby, what wires would i have to tap into for the power etc
behind dash would mean running wire into the car which makes the job twice as hard but you could take it from the ciggy plug feed, switch it and then have that run into the bay or one of the red wires on the ignition barrel there are a few there that are ignition live (turn on only when the engine is running) so that it comes on/off with the key and just run that into the bay.
reason i used the unused fog light plug is the wires are already in the bay and the fog switch becomes the rocker switch (off-on-on) and they switch off with the lights so there's no risk of leaving them on (not sure how long or if they would even drain the battery if left on), but my lights come on with the ignition so maybe running off the ignition/switch would be easier.
Edited by Cymro
ahh right fair play bud, sorry to sound thick but obviously theres more than one wire on the washer jets so if i connect one wire to the red igniton wire, where do the rest go?? lol
the other needs to be earthed so easiest location is the one on the passengers side of the bonnet hinge (the wires can then be held out of the way with the washer tubing clips) or run the other way straight to the negative battery plug
Edited by Cymro
