Read if any knowledge of paintwork! any help would be good
Right...I removed one of my bump strips today on my 6n polo, Once removed I have found that it looks like my car has had a respray but with the bump strips left on so the colour where the bump strips used to be is a completely different shade.
Is there anyway round this other than a full respray:
E.g. could I get just the bottom half of all doors resprayed or would they not be able to blend together properly?
Or is it possible to just respray the area where the bump strips were?
Anyone had a similar problem? and resolved it?
Any help apreciated
thanks in advance
  • Replies 12
  • Views 1.3k
the bottom of door could be repainted and blended up the door but tbh it will still be noticable, even if you had the full door painted, it will be noticable that you've had just the door painted, the very best thing would be to have the door painted and the front wing and rear quarters blended
Any help apreciated
thanks in advance
i removed mine today aswell and now i have a line around where they used to be that i cant get rid of :/
thanks for the reply mate, pretty helpful:)....Might just have to re apply the bump strips as the other possibilities seem fairly pricey for the moment. Might go down to a body shop and get a few quotes though.
if its just like a line and not a colour difference you could always try wet sanding with 2000 grit wet and dry and then machine polishing
Yeah :) I'm gonna have to try something, it seems like the paint under the strip is a different thickness than the car paint, feels like its all lower in, not sure tho, might just be the line of dirt lol
Exactly what mines like, it sort of sinks in. Why are people so lazy when they do re-sprays!
thats signs of it either being repainted with the strip on or atleast relaquered with the strip on, or its been repaint/relaquered with the strip off and the strip refitted when the paint/lacquer was still soft
its not always down to being lazy, its down to costs, if say a car trader had the car they will pay as little as possible to get as much money out of the car as possible, so this could be just having a tiny bit repainted with parts left on to keep price down but in turn it will make them more money in long run
Is there any way around this without putting the strips back on :/
read what i put earlier about wet sanding and machine polishing
yeah I'm gonna try that, i just thought i might have to re apply some laquer, it must be on there for a reason :/ might have to steal the polisher from work
it should have lacquer on there from the factory if its a metallic colour, just wet sand and machine polish and see where it gets you
