Polo 6n Scissor Jack
Well i was wondering where i can buy a polo 6n scissor jack which normally comes with the space saver in the boot.
  • Replies 16
  • Views 1.8k
have seen a few knocking about on ebay, don't forget the towing eye, mine's missing from there!
I've got 3 :) all out of polos ??
get one in the scrappies for a fiver?
iv got loads.....id give you one if you were local
if you value you are life never use one , buy a decent jack , they are nicknamed the widowmaker for a reason
There are loads in the scrappy i go to. It had about 7 polos knocking about last I went, most had a jack, wheel etc etc in the boot.
Do you know any VW breakers in London, mate.
i only carry one if i get a puncture......even then i generally use tyre foam
fuck carrying a 2 tone trolly jack in the car on a dailly basis
mate.....any scrappy will have vw sissor jacks
which scrappy do you use, is it close to london?
My dad knows the people that run this one in west drayton, always a good place for VW's and they are prone to abit of bartering :p and stealing :D:D
Mine is from a Rover 600 - i figured one from a car double the weight would keep it off the ground long enough to change a wheel at the roadside.
Just go to a scrappy and get one with a suitable mating shape from a bigger car. When they fail , and they do so never get under a car held by one, it tends to be the shaft snapping, which has happened to me twice (once when using a Renault Laguna jack on the MK2 Polo), but both had been used far more regularly than they were designed to be.
They are fine for keeping the car up for a few minutes when you get a flat.
I carry a can of tyre sealant instead. Spare wheel, jack etc adds too much weight to the car for my liking! I've had a car fall off a scissor jack twice now, denting the sill both times!
but what do you do if the tire is split or the hole is just too big for the sealant to work?
suprised nobody picked up on this. . . . .
Thanks for the offer rik, yer only if we were local.
call the AA :lol:
