mk3 golf seats in a mk3 polo?
was mooching around my local breakers today and amongst lots of vw's i wish i had there was a mk3 golf se with a rather nice gti'ish interior, red and black and looked a bit like polo gt seats. 8-)
Anyway, it's just an idea but how hard would they be able to fit in my 91 coupe? I'm good with the grinder and welder, and i think that the fronts are almost a direct fit for a 6n.???? What would i need to do?
And then what about the rears? It was a five door golf and i'm guessing there a bit larger than polo ones. :lol:
on the same note, and even crazier idea, passat b5 seats?
Thanks,
Mat.
  • Views 1.7k
Thanks,
Mat.
defo not passat b5s its a big adaption with a mk3 golf seat the sliders at the back have to be modified its very simple just make them narower by cutting a piece of the rail out and welding it together its about 2.5 cm on iether side if i remember right with the b5s and mk4 golf seats its a bit of a squeeze as the actual seat base is a lot wider and then you get the problem with the handbrake as its the inside edge that touches against each other hence mot failure unless you know a tester thats friendly
ahhh cr*p!!!! just realised, 5 door seats in a 3 door car.
oh well.
:roll:
Might as well delete this topic someone.
Edited by VolksKid83
Thanks,
Mat.
thanks for that, i guess that means i won't be stealing the seats out of my dads passat :unibrow:
will watch out for nice three door mk3 golf seats.
on a side note anyone if mk3 golf seats will fit the real MK3 (mk2f) polo coupe??
Exactly what this thread is about!
You can fit 5door seats in a 3 door, you passenger can get in/out through the boot. :lol:
I dont carry rear passengers as the recaro subframes dont allow for the occupants to have feet. :lol:
I'm pretty sure you will find that the 5 door seats have the bit that three door seats have only it's just trimmed over so you could fit a handle not a hundred % on that but I think that's correct.
