Wobble bolts or PCD adapters?
Alright guys,
I'm watching a set of 13x8 wheels on the bay of E but they're 4x108.
Just wondering how much wobble bolts take up as I think it may only be a couple of mm and I got a 6n which is 4x100.
Pcd adapters are so pricey and I don't know of anywhere where I could get them drilled. :-(
Any thoughts?
Cheers,
Tommy.
  • Views 1.6k
Wobble bolts only go +-2mm ish so it would have to be adaptors unfortunately mate
Adapter only job.
Ahh fair enough, cheers guys.
Might work out cheaper to get your hubs redrilled? There is also a possibility of some early Audi hubs fitting, these are 4x108 but not sure if they'd mate up or not.
^^ yes some of the early audi hubs have the same outer diamter into the wheel bearing (40mm iirc) but the splines are bigger on those (again iirc 26mm)
