Any Advice on replacing Rub Strips on MK3 Coupe?
Hi All,
I have a 1992 Mk3 Coupe CL.
One of the rub strips is starting to come off I think because of some rust underneath.
My guess is that the best way to fix this would be to carefully take off the rub strip, address the rust problem, re-spray and then put the rub strip back.
Karl_CLCoupe wrote an excellent FAQ explaining how to remove rub strips but I have not seen any advice on putting them back. Should that be easy? i.e. once removed can I re-use the backing strip and find the right adhesive to put this back on the car or will the parts be too damaged to re-use, effectively meaning if I take these off they will most likely stay off.
Also - why is it that there are lots of comments about 'stupid rub-strips' & people wanting to take these off - do people thnk they look that bad? I kind of like them and want to keep the car as it was just restore it to as new condition (if I can!!)
Any advice greatly appreciated,
thanks,
Alan
  • Views 825
I would have thought, as long as you sort the rust out, and find a strong sticky back foam/ adhesive, they should stick back on ok.
As to the whole removing bump strips thing, at the end of the day it's down to personal preference, it's your car, you do what you think looks good.
Fisher..
Fisher..
Thanks Fisher,
appreciate the advice,
I realise it's personal preference but it really interested me that most comments I see are people not liking them. I never really thought of these as something not to like, if you get my drift... just interested in people's opinions. I guess I'd like the car either way to be honest but my defualt is to keep it how it was meant to be.
(which obviously does go out of the window a little if I decide to respray a different colour but just a little and it'd still be standard, just a different colour.
cheers,
Alan
