kenwood KAC 8452 Amp £60!
Hi Peeps
I've got my Kenwood Amp for sale as I no longer use it. It can be used as a 2,3 or 4 channel amp depending on what you want to use it for.
Its in MINT condition, and that really isn't an exaggeration!!!
Its the KAC 8452 Model, which i've just found out is now discontinued!! It was from the high quality range from kenwood, as opposed to the entry level amps.
Anyway here's some pictures and I've got the official spec info from the kenwood website so you've got the exact info on this amp.
cheers for looking
james
Key Features
High Quality 4-channel Power Amplifier
Single-side Exposure of Terminals for Multi-Installation
Maximum Output Power 800W
Amplifier Features
Load Capability 2Ω Stable
Maximum power output 800W
Rated power output (4Ω)t 70W x 4 (4Ω)
Rated power output 90W x 4 (2Ω)
Bridged power output (4Ω) 180W x 2
Low-pass Filter Yes
High-pass Fliter Yes
Bass Boost Circuit Yes
Power Indicator Multifunctional
Line in RCA (Gold Plated) A/B
Input Selector A/AB
Line out 1 RCA (Gold Plated)
Speaker level Input Yes
Die-Cast Aluminium Heat Sink Yes
Removable Coverplate Yes
DC cable Supplied No
Amplifier-Specifications
Maximum power output (4Ω) 200W x 4
Rated power output (4Ω, 14,4V) 70W x 4 (20Hz ~ 20000Hz, 0.08%THD)
Rated power output (4Ω, 14,4V, DIN:4524) 70W x 4
Rated power output (2Ω, 14,4V) 100W x 4 (1000Hz, 0.8%THD)
Rated power output (4Ω, 14,4V) 200W x 4 (1000Hz, 0.8%THD)
Low-pass Filter 50~200Hz (18dB/oct)(B-Channel)
High-pass Fliter 50~200Hz (12dB/oct)
Bass Boost Circuit 0/ 6dB (B-Channel)
Bass Boost Frequency 90Hz
Input Sensitivity 0.2 ~ 5V
Input Impedance 10kΩ
Signal to Noise Ratio 100dB
Frequency response (+0dB, -3dB) 5Hz ~ 50000Hz
Operating voltage 14.4V (11V ~ 16V allowable)
Maximum current consumption 40A
Installation Size (WxHxD) 380 x 61 x 286 (mm)
Weight 5.8kg
Edited by knappster
  • Views 195
Any offers welcome!!! :-)
