PLEASE HELP: Classic filler neck problem
Hi All,
I just bought my Polo Coupe and though the seller denied knowing anything about it, I have what seems like the classic filler neck rust problem. There's no leak if the tank is less than half full, but 3/4 to full and it drips petrol from the hole in the filler neck.
My question is do I have to replace the tank - I learned that it's one part with the neck connected to the tank, but can I patch up the problem somehow or is that asking for more trouble - i.e. does something exist like a bandage (fibre-glass?) or something to cover the hole or is this really not advisable?
I guess if the filler neck is rusting then it's only a matter of time before the tank too rusts? Or is it particularly because of the daft position of the filler neck inside the wheel arch.
The reason I ask is that a replacement tank is not the cheapest part and is also not the simplest job labour-wise, and I bought this car to have inexpensive motoring!!
As it's such a key part I was thinking if I do replace it only to go for a new part (not to take any further risks re: rust/leaks) and then to take some advice on how to treat the part/paint it with whatever I need to to protect it as much as possible before getting it fitted (no I am not brave enough to do this myself nor do I have the means to lift the car up for such a job!)
I would really appreciate some advice on this - patch up or replace the tank (cheapest I've found is £76 delivered from Fuel Tanks Direct - are they good/reliable? or does anyone know anywhere local to Cromford/Matlock I can get a new one cheaper?
Plus - it looks like that's not nearly the end of what I'm going to need to buy for my new (well, old) little car :-(
Alan
  • Views 1.4k
id say weld it up mate....
Joking lol,
If your going down the route of buying a new fuel tank, have a look at some of the cars breaking on here, you might find one a hell of alot cheaper.
Bump
Get down to your local motor factors and ask for some steel putty (might be called something else) . It's a water/fuel proof putty that you mix up in your hand and can patch such a repair, it can even be used when wet. I used it on my first mk2 and it lasted a good six months. Ultimately you'll need to get another tank. Second hand or new just make sure it has some primer and paint and/or stonechip paint and/or underseal and/or POR15 on it.
It's just a bad design where all the water and road salt hits the filler neck. Prevention is the key, garages would just slap another tank in without any protection. It's also very easily scratched when fitting.
You have to expect to do certain servicing/replacing and general TLC with these cars. Goes with the territory of older cars but once your on top of it they are very reliable.
if you plan to keep the car more than a few months then i would get a new tank , patches /bodges wont last too long and chances are most 2nd hand ones are getting ropey unless you get lucky and find a scrap car thats had a recent one
just doinf mine today ...i fitted a new one several years back and its getting rusty now ,so I've dropped it out for a wire brushing and paint up
its not too bad to change , you will need to raise the car fairly high and it took me about an hour to get it out
If I was to consider doing it myself - and that's a big if, how do I raise the car pretty high - would a couple of those ramps be enough if I reversed onto them and whacked a couple of bricks in front of the front wheels, with handbrake on, in gear and engine off?
Or would that not be high enough?
ramps are about high enough , trouble is i had to loosen the drivers side beam mount to get the tank out , so ramps wouldnt be any use
others report that they didnt touch the beam so i dunno? mines a bread with a non genuine tank
Go to your local industrial suppliers and get some wire reinforced tubing,cut the pipe but for an inch from the tank,fit tubing from there and hold with spring clip.
This will be safe for a couple of years,but that's as long as you can expect.
Alternatively,buy a new tank whilst they're still available and cheap,and treat said area with a good preventitive measure.
GSF sell tanks for £60ish.. I know I've just purchased one! :)
