VW POLO 2001 1.4 SE
Hi all.
My gf bought a vw polo 2001 1.4SE about 2 months ago. Everything was fine when we picked it up had a day before M.O.T aswell. But then problems accured.
Engine management light came on!!! - Reading misfire? on cylinder 3. so we changed HT leads - Plugs - coil pack guy took the light off cleared codes now its still on with the same thing????
Exhaust blowing - Had to get a new cat at £185
Was a rackling noise when you sit it in nautual out of gear but when you put clutch in it goes ???? was told it was bearing on clutch, So had a new clutch fitted (£170 fitted) and it still does it??????
So what can STILL be causing this engine management light to come on??? and the rackling noise to still be there?
Thanks very much for any help as we really need it right now spent so much on the car and not gained anything!!!
  • Views 1.4k
I bought a brand new CAT with a 2 year warranty for £95 delivered from a motor factors on ebay, you really should shop around more.
What is the error code you are getting? Still a misfire on that cylinder? Did you buy brand new OE quality leads/plugs/coil?
Has the engine had a compression test done? Does it lose any oil or water?
Hi,
The cat they was 1-2 of them and this one had the heat shield on etc so thats why it was more expensive.
The parts are all good quality we know that wouldnt buy anything less.
The error is random miss fire and cylinder 3 miss fire.
No not had a compression test done yet
My clutch has always had that rattle, then my clutch went, and had a new one fitted and it's still there too! Really puzzled by it!
If any mechanical minded person could shed some light on this, you would be helping two people out!
Ta
Thanks for the help
Your Cat cost less than mine. Mine was £270 inc labour charges. Although it passed the emissions test easily with just 6ppm.
Edited by wildman_33
