Corrado Rear bench in a Mk3
Have a corrado bench that needs fitting in a mk3, the match ups ok but has anyone got any tips or build advice.
Etches
  • Replies 9
  • Views 2k
BUMP
anyone?
  • 1 year later...
in trying to find out my self man i might follow the tips on club gti for mk1 golf
Being a Corrado man myself and having ripped many apart, the way to do it properly would to cut the lower seating mounting rail out of a corrado shell. This would have to be welded in, then lower cushions will push fit into this as per in a corrado.
Pictured here in the middle:
If you want the centre arm rest, you are also gunna need the mounting bracket which is attached to this frame rail:
Of which I have one if you are interested.
Then its a case of working out brackets to attach the seat backs, again could be stolen from a corrado and the tops via a locking hook system so they can still fold flat.
Gimme a shout if you want any more info. Sounds like a lot of work i know but i reckon could be achieved relatively straight forward if you can get the right donor bits.
Edited by StueyB
so i would need both of the above?
if you want to fit the rear seats, and the centre console then yes.
However that is a fair amount of work to do, especially if you're not a confident welder. To weld in the support rail i'd say you'd need at the very least the rear doorcards and the rear half of the carpet out. I'd also remove the fuel tank cause thats under there.
Personally i'd experiment with fitting the corrado covers and foam (from a non console rear bench) onto a polo frame. That way it may be easier
But thats just me, good luck whatever you do!
Tis a good shout.
Although i'll think you have fun getting either to match up based on the design and shape of both.
Flat bench would be easier for sure but if I did it I'd want the late spec hump look otherwise IMO there isn't a lot of benefit.
ye well one of my friends is a welder and fabricator so ill see what happens there will be a build thread on this lol
build thread is up pics this week
