corsa 2.0 redtop engine
For sale is my corsa redtop, it started off life as a 1.0 12v 3 door envoy model, which is the lightest corsa model weighing in at just over 800 kilos, giving more power per tonne and ONLY insurance group 2. Has been replaced with a 2.1 litre bored out redtop engine from an astra which was completely rebuilt 3000 miles ago
- T registration (1999)
- 5 months tax
- 5 monthx m.o.t
- Ready to drive away
- 1.0 12v on logbook - up to new owner to change
Spec:
- 2.1 litre bored out astra engine
- Coscast head
- Chipped ECU running high octane fuel
- F20 gearbox
- 78000 on clock but recent rebuild
- Mtec power-cap
- Prospeed straight through with decat
- 4-2-1 steel manifold
- Custom air filter
- 2.0 grooved brakes
- 15" multispoke wheels painted red
- laguna front splitter
- Uprated 2.0l fan
- Push Button start with cut-off
- Remote alarm and fob worth £500 (has option to have remote start and option for the fob to vibrate if someone goes near the car)
- Roose motorsport cabling
- Ecu relocated to inside car
- Debadged front and back
- Debadged grille
- Angel headlights
- Black and red gsi door cards.
- Uprated 2.0 radiator
- Calibra leather front seats
- Sony headunit
all cabling left in car to hook up a sub and amp (left in by prev owner)
black and red gsi door cards.
The car had the following fitted in last 2months:
- Coscast head
- Timing belt kit
- Heavy duty battery
- Relay for bigger fan as it kept blowing out
- New alternator
- New starter motor
- New rear wheel bearings x2
- New trackrod ends
- New bushes
- New tyre on back
Bad bits (going to be very picky):
- Small rust patch on drivers door
- Very small rust patch on passenger side door
- Very slight wear on drivers front leather seat from getting in and out
- Horn doesn't work
- a LSD gearbox would be more sufficient as the car torque steers in first 2 gears (and wheel spins) but as soon as you are used too it, its fine.
- few dings and scrapes here and there, most of which I suspect was from when the conversion and engine rebuild was done after looking at them closely
** I have silver metal spray and a OMP roll cage which I could include at an extra cost and also 1x cobra daytona bucket seat + harnesses as my sole intention was to strip the car out completely and use it on the track - these can be negotiated seperately if you want them **
£1500 O.V.N.O but I would prefer a swap as I use this daily and cannot really be without a car.
bump for a fast fun car
Swap for a lupo 44k miles good cond, pm me
wish you were a bit closer and i had some more spare pennies!!
