Where would rust on a polo mk2?
hows it going, I'm going to look at a mk2 polo coupe facelift soon and I'm just wondering where should i look for rust, or is there anything i should check for? thanks
  • Replies 12
  • Views 3.7k
Sills, petrol tank, rear seems, tailgate, bottoms of doors, valance front and rear, arches!!!
From experience the early coupes i.e A and B plates were better built we've had a c and d plate and both were poor.
@ mk1 lx : i would but I'm in ireland thanks.
@ DAVID & JACOB : Thanks for that, i dont understand a need b plates though
http://cars.donedeal.ie/for-sale/cars/1470739
This is the car, i think it looks pretty clean in the pictures :)
I think he means A and B Reg ie:- 1983- 1984 years
I'm confused now i dont know whether its a mk3 or a mk2 facelift?
We call them Mk3s on here. Same thing. But you won't get one earlier than an H plate (1990/1) so disregard the comments about earlier ones being better. They all rust. They are also at the age where they rust everywhere. Battery trays and fuel tanks are favourites though.
you i was told the tank and battery tray too, thanks
its a 1995 I'm looking at? when did they stop making mk3s?
MK3's were made until 1994 ( M plate) but these were run out models called match.
In 1994 the 6n mk4 polo was introduced models were 1l, 1.3 and 1.6.
I misread your orignal post as i didn't see the bit about facelift model. The mk3 was introduced in 1990/91. If you can afford it by a gt or 1.3 genesis as these have rev counter, gt sterring wheel and nice interiors.
or buy any other model and pick a rev counter set of clocks up for anywhere between £20 & £30.
Battery Tray & fuel tank (where the filler meets the tank) are main points, sometimes arches (especially if theres arch/sill covers fitted) and lower doors.
Edited by Cymro
What a carry on.
The MK2 facelift is a '90-'94 car made in Spain. It seemed to rust less than the late German cars of '86-89', (but none were as remarkably rust proof than the '81-'85 cars).
Apart from around the front arches,the rust tends to be on the rear half of the car. Oil leaks from gearbox remote and engine gaskets tend to minimumise the damage to the floor,even at the vulnerable front jacking points,but the sills and box sections around the rear arches suffer,and the petrol filler pipe is vulnerable,as is the double-skinned panelwork around and behind the filler cap flap all the way down to the sill.
I was going up to get it yesterday but the man didnt answer his phone so he just lost out on sellin the car..
rust under the battery on an early Polo can be a major job to fix as you have to strip a lot of stuff away to get in at it and prevent from catching fire once the welding starts. There is no repair panel available (as far as I know) as it isn't a separate panel that the battery sits on, its part of the bulkhead.
You also need to dig out loads of seam sealer to reach the seams and spotwelds to remove the rusted metal and to do the job properly you need to replicate the channel to drain rainwater out under the battery via the wings. The original pressing had provision for this. You also need to make a new clamp stud (per the original design) so that the car battery can be fixed securely (MOT failure if it isn't) and if you get it in the wrong place it will be difficult to fit a battery in as the area is quite recessed.
Probabaly best to walk away if you find one with rust there.
