Advice on buying a 6N
Hi to all, newbie here, but even after 10 mins looking about the site, if I buy a Polo I will hang about.
Anyway, I am off to see this later today
1995 'N' VW Polo, 1.3 CL, Petrol, 5 door Reliable. Tax October 2010, MOT May 2011, 117,000 miles, Good Tyres, Green £475 ono
How does this sound? Anything I should look out for (Polo specific rather than general used car). Also, would this have ABS?
Edited by Dan.
  • Replies 18
  • Views 1.4k
117k doesn't mean much it all depends on how it's been driven.
There is so much to check for, in general and in polo ways.
First of all i'd check the sills, around the bay and behind the wheels (wishbones) for any major rust.
Then I'd check for rust in weird locations such as in the centre of the door or around the windows, as this would tend to suggest water being in the panels.
I'd then check the engine bay.
White gunk around the oil cap or the dizzy would suggest water in the system.
I'd also check to see if it's hot, if it's not ask them to start it up whilst you stand and check the exhaust doesn't push out really black or blue smoke.
Blue smoke is oil burning and black is just cruddy burning.
Take it for a drive, check the steering sits centred. If not, tracking is out. If the steering wobbles then it could be unbalanced wheels or maybe buckled wheels.
Brake, fairly firmly, see if it pulls to one side. Also if it makes any sort of grinding sound, it probably means brakes worn and you have metal on metal rubbing.
Changing gear, is it easy to put into gear. Does it whine? Whining sounds usually mean the box is about to go.
Clutch. When you press the clutch does it make any loud ticking sound? This is usually a broken release bearing, meaning new clutch needed.
Suspension is most likely going to be as bouncy as a barge on choppy water. Just check it doesn't creak loads by applying your weight to a corner and seeing if it bounces.
A good suspension will return to it's original point without bouncing up and down like a shot one will.
Check theres no drips below the engine bay. Drips can indicate water pump, power steering, coolant, radiator or a mixture of these being fucked depending on location below the bay.
When it starts, let it run. Check to see if it idols nicely, around 900rpm. If it jumps up and down like crazy this indicates the thermostat or temp sender is bolloxed, common polo prob.
Check the power steering works properly by turning it to one side, if it turns back to centre it's good. If it gets stuck towards full lock it's going to be broken or almost gone.
Next for electrics, check the central locking works, key into door and just turn it left or right but not hard, you don't physically need to turn the key too much, just enough to make the connection. Quite common for the pumps to go after alot of use.
Next check the lights work behind the clocks and dash. Then check the electric windows, common problem on polos is the window regulators burn out and stop running.
Check all the lights and bulbs work, hazards on, sides on, reverse and get them to stamp the brake.
Other things i forgot to put in earlier.
Check the boot well for spare wheel (probably space saver, along with the jack, locking wheel nuts and other bits.)
Check there is no dents on the metal work inside the boot well or engine bay, as this will be damage from previous incident.
Remember, it may only be £475, but with only a few bits having to fixed it could be cheaper to buy something slightly more expensive.
Other people will probably add more but this is the best i got.
Oh and it probably won't have ABS. But ABS isn't everything.
Finally, haggle. Everyone enjoys a haggle. I'd haggle just to make sure it has petrol in to get it home and to drive it for a while.
This should become a sticky!
D77, you are a star, thank you :)
Is it local to you?
Does it have power steering?
I wouldnt bother if it doesnt have power steering.
Lol! Why not? Not exactly heavy steering without it!
Mine's not got power steering and it's fine! Less to go wrong as well!
The power steering is one of the only things the 6n has going for it!
About 3 miles from me
It was crap and lime green (I am sure someone will correct me on its name) that had taken on a matt look to it.
Cosmic Green? A light metallic colour?! Best colour that is!
Actually I think the standard fit skinning up table is the only thing going for one.
ha ha pmsl!!! thats the exact thing i thought when i first compared it to my passat ha ha!!
LOLLL best post ever
lol i got some good advice don't buy 1 buy a 6N2 :p
can you get a 6N2 for 400 big ones?
regretfully no, otherwise we'd all have one! :-)
I don't get it... :shock:
stoner <3 sal.
Could not find one that was local and within budget, so I went and bought a 2nd BMW, this time a 1994 525i
