Will they fit?
Hi there,
I was thinking about putting some new wheels on my mk5 polo gti.
The wheels I have found have the following specifications:
Offset: ET35
PCD: 4x100
Rim Width: 8J
Rim Diameter: 16 inches
Will they fit properly or will i need to make some modifications? I was concerned about them sticking out too much as they are 8J.
(atm my car is completely standard mechanically with the original wheels and suspension)
  • Views 932
I'm on 16x7s atm, they're a bit tight, you may need spacers or stretch to stop the inside fouling the damper, what size tyres are you looking to fit?
Edited by dirt_monkey
You lowered tho arnt you? If his is standard they should fit.
I have no idea tbh, whatever I would need to make them fit properly. Oh yeah, these are the wheels, if this helps:
http://cgi.ebay.co.uk/ROTA-CUP-ALLOY-WHEEL...351e4c1ffc9d9c6
Would I have to lower my car if i got these?
Thanks for your reply
