Number plates FTL
Right, i have a set of metal pressed plates on my 6n but every so often they seem to hang or fall off, i have replaced the trim tape 5 times since last tuesday and they just wont stay on!
Any solutions that dont include screwing them on cause i dont like the idea of drilling them :)
  • Replies 8
  • Views 1.3k
plate holders.
Why don't you want to drill them? Are you not confident holding a slowly rotating piece of metal?
Probably because it looks shit when plates are drilled in!!
Use heavy duty velcro, the plates will bend before you can get them off it's that strong.
I just dont like them drilled, is that what you use indy?
Trim tape is plenty strong enough....you're not using it right!
Wipe the surface with alcohol free soap, very lightly, let it dry and then stick them on. They dont stick well to damp, dirty places or even polished surfaces!
I do wipe it down but never used alcohol free soap, one problem i also have is getting the old trim tape off!
Cheers for the help :)
Iirc before the mods decimated tidied up indy's thread, there was a couple of posts where he put his on with Velcro and when he came to remove said plate, it bent in half!
I'm sure Indy will correct me if I'm wrong...
To get old trim tape i recommend caramel/fudge wheel. They best way to get get the glue from trim such as side strips or badges off!
Its worked for me no problem, so maybe you are buying crap quality. I buy stuff thats meant to hold on side strips for life....from ebay!
