2005 Polo GT headlight change.
Having moved to France, I need to fit the appropriate headlight units. Could anyone offer any
advice on how to go about this? I am assuming that there is no built in device to facilitate this change - that
would be too simple!
  • Views 929
You say that, but on many of the newer VW/Audis with Xenons you can actually adjust the beam pattern from RHD to LHD spec using the diagnostic software 8-)
In your case though I don't think you'll be able to do anything other than buy a new pair of headlights.
Also, (I can't remember what the standard set up is on mk6s) but I'm pretty sure the rear lights may need adjusting too. So the rear fog light is moved to the left hand side.
