Wireing Fogs
Alright people,
Right i have a 95 1.0l polo an i have got 16v bumpers with the fogs i have the light loom with both fogs, headlights an indecaters an also have the switch with the front fogs on it i was just woundering weather they will work if i jus plugsed them up or is the loom that goes from the switch to the front panel diffrent?
cheers daz
  • Views 576
at the risk of sounding like a mod and a jedi......this should probably be in the ice section and... use the search
http://www.clubpolo.co.uk/forum/index.php?showtopic=166235
you need a wire from back of fuse box (under the steering wheel behind drivers glove box) to the switch
