Rear arch rust
I got my polo about a week ago and it had some rust on the rear arch first thing i did when i picked it up was take it to a body shop to see what i would be paying, i was told that he could fix it but it would only come back in 2 months, and the only way to REALY fix the problem was a new panel which seems pretty stupid to me. its got me a little worried as he quoted me £350 for a new panel fitted and painted. he said it was a common problem (don't know weather he meant cars in general) is he right? sounds to me like he hasn't repaired previous arches properly.
The panel has plenty of good metal left and is very solid.
Richard
  • Replies 12
  • Views 2.5k
tbh the guy is about right. the only way to fix it is to chop out the rusty metal and weld a repair panel in. a cheap bodyshop might grind out the rust as best as they can, then skim it, but the rust will almost always return.
£350 is a good price to have a new repair panle fitted and sprayed imo
What car is it... have any pictures of the rust?
If its rusted from the inside out then the only option to stop it returning is to cut it out an weld in a new piece.
Mines at the body shop at the moment having all the rust done... its not a cheap thing to do..
yeah its pretty much right , the cheap option is sand down the worst and paint it up to look good and it will be back
chances are its coming from inside out or between 2 skins , so needs cutting open to be able to get it all out
£350 doesnt get you alot of work at a bodyshop anyway
Show us some pictures if you can. Depending on how bad it is there are always things that can be done.
right i can get some pictures up but they will probably confirm what you guys have said. tbh its made me a little happier knowing that the guy wasnt just trying to rip me off. so is this pretty much the case with rust in all areas on the car or will it just be round edges where two skins meet.
thanks for your answers
Richard
pictures will be up later as I'm about to leave for work.
Yeah,rust is literally like a living disease,its metal's cancer,it grows and spreads,and it must be removed entirely or it'll just spread again.
New metal is open to infection,it must be properly protected in a seal of wax/paint/stonechip.
So you can see the challenge in restoring rusty cars..
I'm a pikey so i chipped off a huge bubble of rust sanded it down to a smoother surface then used "Krust" made by hammerite and instead of getting rid of the rust (basicly eating it till there is metal) it hardens it back to a solid surface then anti rust primered that (hammerite again) and then filled and it looks like a solid arch :D no worries
;) pikey win!!!
;) pikey win!!!
looks solid........... till the suspension strut punches its way through your turret cos its been eaten away by rust
to be fair though, if its just surface rust i'd do the same on an old polo. not really worth spending big bucks on them. having been down the route of buying a car with rotten arches and proceeding to get them fixed, i dont think i would bother again, as you just end up finding more and more cruddy bits, better off just buying a car in better condition
My mate had 2 new rear arches fitted and painted along with 2 new sills on his CRX for £350.... Seems abit high to me!
here is the rust on the rear arch
and some rust caused by damage on the drivers side I'm guessing the same deal as above (new panel)
your mate got a bargain, bet the parts and materials wouldnt leave you much change from £200.
richard: that bit around the rear light is just surface rust and could be fixed without needing to chop any metal out. the bit around the arch i would personally get it cut out and a repair section welded in. (if the bodyshop are any good, they will only cut out the rotten bit, then trim the repair panel to fit)
click link to see what i mean
http://retrorides.proboards.com/index.cgi?...mp;thread=88328
thats incredible work but yeah i can see now what needs to be done. I'm going tomorrow to see about prices maybe even find out the price of a full respray with the rust sorted. Figure i might as well go the whole hog and sort the rest of the body now. pointless getting it fixed and then resprayed later.
