1992 B3 Passat Estate 1.8L
Hi guys and girls just putting feelers out for this incase any one wants an unbreakeable parts chaser or workhorse. My mate Jamie had it before me and he did loads of motorway work in her going to see his girlfriend and Run to the Sun. I've been using it to collect parts and it has just gone to the Isle of Wight for Bestival and did not miss a beat.
Make: Volkswagen
Model: B3 Passat Estate
MOT: Until Sept 2011
TAX: Until March 2011
Engine size: 1.8 8 valve 90PS SPI
Fuel type: Petrol
Description:
New cam belt and tensioner
New plugs and leads
Oil change and new oil, air and fuel filters
New front discs and pads
New front springs and top mounts
2nd hand Boge uprated shocks and springs
New track rod ends and rack boots.
New o/s/r wheel bearing.
New coolant temp sender and repaired the temp gauge PCB.
It has done 166k but doesn't drive like it at all. It returns 35mpg, is moted until September 2011 and taxed until March 2011.
Bad bits are that the heater air direction control is broke. Needs a new set of controls and a tight cable freeing off. One fuel tank strap has snapped but I will sort that out and the tailgate needs paint where I welded two plates in as the number plate lamps feel out, again I will try to sort that out.
Images: DSC00190.jpg
Price: £475 on standard 14" steels or £575 on G60 steels
For more info give me a call after 6pm on weekdays or anytime at the weekend on 07988842998 or drop me a PM.
Cheers, Tom
  • Views 235
hello mate, would you be up for any swapsfor this? i have my scirocco for sale on here and would do a straight swap for this if you would be interested? I'm in bilsthorpe, between newark and mansfield so not far away.
what rust does it have?
Sold with the G60s!
