Mk2 Polo Coupe S
Hi,
Just wondering if anyone knows roughly how much a mk2 polo coupe weighs fully stripped out? Just a dash and two front seats :-)
Cheers Alex
  • Views 1.3k
700ish kg? perhaps less..
You save very little by taking the rear seats out,it isn't worth it. You save more just by removing the spare/jack/tools.
But then the seatbelts are a few more kilos,which post '84 cars must have with the seats.
Carpet again is nothing,but the sound insulation below it is heavier and always worth removing.
Yet this lot still doesn't get a coupe to 700kgs,even in the early models which were around 20kgs lighter. Not far off for an early non-sunroof model though,especially with alloys - but with the steel slider in a car under 25years and its still gonna be 730kgs minimum.
Mikey's right. I had mine weighed and it came to 760kg. I thought it was 730kg but I've just checked. I've removed about 30kg of weight from the car when stripping it out for the re-spray. So 730 would be about correct.
