how to Upgrade/improve your delocked handles
So I hve delock handles on my polo (th ones you get of the rear doors of a 5dr) and yesterday I went to open the passenger door from the out side and the hands hmjusy pulled but dint open the door then I heard something drop! So I started to worry, door wouldn't open from the inside (turns out that was something completely in related, new chrome door pulls popped of it's pivot,) so had to rip the door card slighty to get it off to open the door, any ways with door open and handle out I noticed part had snapped
(compared with working one!)
then I had a plan, I remembered that the standard "locked" handle had metal catches etc
so I set about removing said part as it looked as if it definately came apart! All I had to do with a hammer and small screwdriver or something similar was tap the pins out (try both directions if it doesn't work 1st time!) and slide the catches out! Like this
and repeated this on Both "delocked" and "locked" handles so I had 2 metal catches and 2 (1 broken) catches! Then I swapped them over but unfortunately they didn't go straight in! I couldn't get the pin in them to secure them so I had to carve a bit of th plastic out of the handle slot bit! Like so
then I put them all back together!
now I have a more durable/reliable door handle and I won't be ripping more doorcards, also if you have a smooth boot and they were to snap only entry would Be thru a wondow!!
Hope it come in handy!!
  • Views 807
Have you fitted central locking? Or did yours come with that?
