gti xenon headlights on a non-gti
ok so I've got a set of gti headlights, ready to put into my non-gti.
how easy is this to do? I've searched the "search" but couldnt find anything to answer my question. Has anyone done a 'how to' guide?
also, is it possible to use just normal bulbs in them? obv they wont be xenon but i dont mind about that. i bought them purely for the look of the actual headlight, and then plan on buying a xenon kit to use with them.
they headlights didnt come with bulbs so can i just put a normal bulb in, or should i buy the proper gas ones off ebay - someone said they are loads cheaper than the £90 at dealer!
please can someone shed some light ;)
  • Replies 63
  • Views 5.2k
don't no much about wiring and bulbs but to put the lights on you have to take the bumper off but that's not really hard, its about 10 screws i think.
Projector lenses like the one found in the GTi lamps are designed to work with HIDs, i found when i first got my angel eyes using standard halogen bulbs was borderline dangerous because they were so dim. I now have an aftermarket 35w HID kit and it is fantastic, never looked back! So i would reccomend getting the HIDs in there. Don't be tempted by those £5 "Xenon Blue" Halogen bulbs, because whilst they are a bit brighter they run alot hotter and will melt the inside of your lenses, where as HIDs are a type of electric arc lamp so run far cooler than a filament bulb
ok so il be alright using a hid kit with them. but normal bulbs will be too dim? thanku for you are help!
would i just ignore the ballast on the actual headlight itself then? and just use them as empty headlights? (if that makes sense?!)
and which hid kit would you reccommend?
thanks! :)
Edited by laura-lou
Dirt Monkey is right, but not completely the only reason the lights were dim with standard bulbs is because the FK angel eyes are crap! You can run the GTI lamps with normal bulbs, but its recommended to run HID because A: it will look better and B: There designed for HID's..I think if they were mine i would just buy aftermarket HID kit and put them on because i don't this normal 6N2's have the loom for the HID's.. Don't quote me on this..But you might aswell sell the standard GTI ballasts and fit aftermarket ones..
^True that! With whole kits from about £30 , you cant go wrong! Plus they're dead easy to fit.
Ditto!
Dirt you had any problems with the level at which you HID's sit? Mine fails MOT every time because there pointed too far down!
Dimz
yeah my bf got a hid kit off ebay for about £50 and its really good. i was planning on getting the same (obv right one for my car) but i just wanted to make sure i can use a hid kit with the gti headlights. do i just discard the old ballasts then which are currently attached to the headlights?
if i used normal bulbs until i got a hid kit, would the bulbs just fit in these headlights? i cant see where they would go?!!!
and can anyone tell me which hid kit to get?? ie what kind of bulb?
Edited by laura-lou
I'm not sure because i haven't seen how the GTI Lights are inside..But sell the GTI ballasts don't throw them away, put the new ballasts in the carriers, then put the bulb in and run the wires through the hole that the old wires used to run through to get to the ballast.. :D
If not take pics post them up and ill photoshop what you need to do :)
Ditto!
Dimz
My headlamp adjusters are broken anyways, so mine are pointing at the floor lol :( if you loosen the top bolt on the headlamp and tilt the whole unit back then you can raise the beam that way, and re tighten. I was contemplating re-drilling them to force the beams higher.
Ditto!
Dimz
Ah yours did what mine did, i repaired the headlight adjusters but no joy to be honest..was going to DIY the lamp to figure a way to lift them inside the lamp rather then moving the whole unit!!
Edited by don_stavrou
Meh, that would probably be the more intelligent thing to do!
Dude we should just do what laura lou did..they buy GTI 1s lol
I hate my angels! if i spot some GTI 1s I'm buying even if they have a broken headlight lens lol just rebuild!..lol
just opened them up and theyve got the bulbs in.... so can these just be put straight in as they are??
YEP!!! :D
I know mine have been nothing but trouble since i got them!
ohh ok!! quite shocked cuz the lad who sold me them said they didnt have bulbs...and I'm sure they are a lot of money!!
if these work i'll faint cuz i hardly paid a thing for them!
few brackets broken but found them on ebay for £16. will have to go and have a test.... :)
GO GO GO!
XENON'S AT THE READY!
PICTURES WOMAN!
:) fingers crossed
GO GO GO!
PICTURES WOMAN!
:lol:
HIDs ARE GO!
i wish... just trying to test them but didnt want to have to take the bumper off. looks fiddly...
not that I'm actually doing the work.... I'm sat here drinking a nice frijj milkshake and observing!!
Bollocks to you! its easy!..
4 Bolts up top, i think five-ish in each arch, 1 under each indicator and 1 under each for light grille.. Ta Dah!
Dont forget the four plastic clippy things under the front!
(unless you're clever like me and have lost most of them)
