Help with bodywork
I got rid of some rust, filled it smooth, primered and then sprayed. But I'm too impatient so it went a bit tits up. So now I'm left with different coloured squares around my polo. How can I fix it and make it blend in more?
Its darker!.....
Deffo needs rubbing down again, 2 squares!
  • Views 1.3k
you have not feathered the paint out you need to sand it back using different grades of paper til there are all bands of paint ,premier etc thats how you blend it in
shouldve asked first..you dont just mask squares and paint it , that will never blend in
<click for response>
Edited by DubLass
helfords coler mach lol?
I would never just paint one repair area, always respray the whole panel with properly colour matched paint, it is very hard to blend new and old paint, and even if its done well it will still be noticable.
Yeah I kinda knew that..as you can imagine I wouldn't attempt to do a massive area because it would be even worse haha
I'm gonna rub down tomorrow and try and do it again.
with this type of paint give it light coats of paint,dont be tempted to put lots on as it will darken up as well as run
two passes of paint and have a cuppa,then another two passes if needed.
I've rubbed the square down and it looks better already ha
And then a black cloud formed over the house and its bloody raining.
So I've rubbed the square back down, so I can see the layers of paint and a tiny bit of metal again...what now? (I can see blue sky coming again)
Edited by DubLass
