6n2 arch rolling
Need my archs rolling else ill have to ride sky high
one of my mates who does my bodywork doesnt do rolling and said that he thinks it will probily cause the paint to crack as 6n2 archs are double skinned?
ill probily be getting bandedsteels to come do it for me
so the question is, anyone had problems with paint cracking or anything else due to having theres done?
cheers
  • Views 2.5k
I'm in the same boat as you so would also be interested to know
mine never cracked...because of the fact there double skinned!!
Its a bigger bend radius. Banded steels did my rears. Heated, rolled and no cracking.
Fronts can do. as there single skin the bend radius is tighter so more prone to cracking if the paint wont flex to the radius.
Bare in mind with them being double skinned. They dont roll flat. But its a good 10mm more room.
X2 only had the rear done though but no cracking on the paint.if you have any rust spots though its defo going to go on you so just have a mooch under there. :lol:
Cool cool well I need all the room I can get tryin to get 9x16 et15 under
good luck with that
my schmidts rubbed on massive bumps after rolling and there 15x8 et15!
Oh right, might just get the rears done then, and get smaller adaptors up front
mine are 15x7 et 23 with 25mm adaptors, might change front to 15mm adaptors
Cheers for the replys :)
