rear sill rust
just got a mk2 1984 b van it looked ok but now after a realy good inspection (with a screw driver) iv found that the rust on the drivers side sill at the rear is worse than i though. I'm going to have to take out the fuel tank to chop away the rust airea but i cant jack up on the sill as it is f***ed and iv herd you need to drop the rear beem to get at the tank. has any one got any idea how i can jack the car and remove the tank????
thanks henry
  • Replies 11
  • Views 1.4k
just jack it off the beam and find somewhere solid to axle stand it.
You weren't actually considering doing this with the jack still under were you ?
no but if i cant jack on the beam and put a axle stand on the sill or the other way round I'm in a bit of F***ed :D
any idear of a solid place all i can think of is floor pan under there and that is going to bend :D
jack on the beam /axle , then put the stands further along the sills or on the back edge of the footwell with some wooden blocks to ensure you dont stuff the floor in
remove the jack and youre free to drop the beam
id stuff some wheels under the car just incase it slips off ...so it wont kill you
ahaha good plan
i also thought about maby bolting on a peace of 2"x4" throught the seat mounts and see how that works and the wheels too
cant put stands on the wheels as they wont let the axle drop
ahah yer
i ment what you said buy putting the wheels under the car in case of sliping dont want to get squashed :)
You can remove the tank with the rear beam still in place.. I know I've done it with the car on ramps. It may be a bit harder but it can be done.
i would have to jack it up realy hi to do that though and I'm only on axel stands
ill give it a go and see what happens
you most certainly cannot on my breadvan ..maybe coupes differ but theres not a chance in hell on mine
Perhaps different style of patten tanks ?
anyones guess...looking at mine theres not room between the axle mount and arch to get the neck through
