ugly black strips..
hello i have a p reg 1997 1.4 16v 2 door polo along the door and rear quarter it has the standard ugly bump strips! are these just glued on? and if i take them off will it need spraying underneath them? can i have some advise on best way to remove these thank you.
  • Replies 18
  • Views 1.8k
I am about to do the same, i have been told that they are just stuck on with glue, and you can use a glue and tar remover (spray can, or whatever) and a credit card or something like that to scratch away the excess glue with no damage to the paint work.
Also using a hair drier or something hot to melt the glue may speed up the process...
been told it takes time, and effort... but the paint underneath usually isnt too bad and may just need a few t-cuts
i haven't tried this myself, and not 100% about using heat, so do at your own risk!
good luck
i did mine a couple of days ago,easy job,just take your time and you will be fine.
all you need is:
old flexi credit/bank card (i really recommend a old one because it will get bent out of shape)
hair dryer
t-cut
cleaning cloth/rag
most importantly........time
simply slide the credit card behind the black strip to break the bond,dont worry,its only held on by foam sticky pads,then when you have lifted it enough to get your fingers behind it,gently pull it off the rest of the door and chuck it in the bin.then get the hair dryer,stick it on full heat and run it across the remaing foam residue stuck on the door.dont just point it in one area though,run it from left to right to avoid heat build up on the paint.the when the residue is warm just roll it off with your finger/thumb.after you have it all off t-cut the area and hey presto! 8-)
word of warning!
i ended up with 2 massive blisters on my thumb with rolling the residue off and your skin on your fingers/thumb will get very hot! ouch. :shock:
good luck! :-)
is this the same for the 6n2 as i think there's some small holes underneath but not too sure
not sure about the 6n2
Edited by POLO84
so mine being a polo 1.4 16v 1997 would mine be the 6n or 6n2?
6n :)
all you need is:
hair dryer
t-cut
cleaning cloth/rag
word of warning!
good luck! :-)
haha ile wear gloves then :p thanks mate very helpful i will look into doing this on week end then. cheers
6n :)
awsome cheers bud my mate has a 6n2 i think? its a 98 ? hes took his strips off i will ask him about these holes..
good luck
well i reckon i will attempt it this week end i will let you know how this goes:P
good luck
Hi Mate,
there are no holes :)
It's easy job if you buy Tar and Glue remover from Autoglym.
I have done my couple of months ago and no problem at all.
6n :)
The 6n2 came in around 2000 (W plate) so the 1998 will still be the 6n.
Best thing is to do is use a 'Toffee Wheel' Its a wheels which goes into the end of a drill and it basically spins and rubs the glue off easily, took me about 30seconds to get whole off.
Dont worry it doesnt damage the paint!
Just because I want to be entirely sure, and cause I don't have the money to correct it if it needs extra work...
Is this really as simple as taking off the strip and T-Cutting?
I have some T-Cut Colour Max (with the little lip stick), I'm assuming this wouldn't do the same job as the colour restorer? Anyone notice any highly noticeable colour variance to the surrounding areas?
6n2 Bump Stripes
They are stuck down and have clips, so when removed they have holes behind them which will need filling and respraying.
Hope this clear some things up.
Pete.
6n2 Bump Stripes
Pete.
I thought there were holes (6n2) but wasn't too sure, thanks for clearing that up
hello mate where can i get one of these toffee wheels?
BTW, it smells nice too when you use it.
