HELPP NEWBIE
alright people, I've been a follower on this forum and now its timee for me to look for a car. I'm 19 and will be looking at polo mk7/9n3 for my 1st car.
Its gotta be a 1.2 or 1.4 and i was just lokoing for a thread on buying advice and problems in relation to polos.
Anything i should be looking for?
THANKS IN ADVANCE :)
VIC
Edited by dhunnav31
  • Views 517
GF's got a '03 9n which she's had from new...
+ points are that it's still on it's original exhaust, springs and shocks and rear brakes. Fronts have been changed once...
- points...
Electronics that control the dash noises failed - expensive fix.
Throttle body failed at 60k - expensive part, plus expensive labour (unless you can find one on ebay for £25!)
Rear washer leaked at joints in the pipe and where it goes into the jet... (I ended up re-building that after the garage failed) leading to a mouldy boot.
Rear wiper misses a big patch in the middle of the screen. trieddifferent blades etc... always does it. VERY annoying on a car that shape!
High level brake light failed recently, and it's practically impossible to remove the trim to get at it without breaking clips off!
The rearmost bushes on the front suspension arms are awful! It's a known design problem... again, EVIL to change! they lasted 60k (which is good going aparently!) but near the end of their life killed tyres... not knowing about the bushes (particularly with a fresh MOT!) I checked the tracking, camber etc a couple of times before I found the bushes!
Other than that, if you can cope with the stupidly light steering and the complete lack of feel when you're driving, they seem good! (I say that, I'm sure normal people'd hate my 'rocco, saying it's too heavy, noisy and demanding to drive... "horses for courses!")
