i have a leak!
it has just chucked it down and my drivers footwell is soaked i have checked the sun roof drainage and the drainage holes by the wiper motor and they r both clear and not blocked really confused as to what it can be any ideas????? its a 2000 6n2 1.4 mfi
Edited by vwadam
  • Replies 8
  • Views 1.6k
Same problem :(
Drivers footwell in my wife's 6N2 was wet.. I haven't checked the sunroof but did check the scuttle panel and it's clear.. any ideas guys?
this was a big problem in my 6n and turned out to be the pollen filter and the heater matrix aswell
just a thought
Alex
If it was the heather matrix then it would be losing coolant right?
Ours isn't.. I'm thinking it might be the sunroof drainage but need to get round to checking it..
check the door seals!
chalk powder or something similar on the seal. Hose pipe it for abit and see if anys leaked through!
Thanks for the tips guys. I think I've fixed it, stuck my finger in the rubber star shaped gromet and it was full of gunk :oops:
So.. I used some Satellite Coax cable (just the right thickness and strong enough) to push from the drain hole in the sunroof all the way through to the other end and cleared out the muck.
I then ran some boiling soapy water down it for good measure.
Can't be sure until it rains, but gut feeling is it's fixed :)
Mine is leaking into passenger footwell as well. I don't have a sunroof though. My seals are fine. Any other ideas?
have a look at the door, my drivers side door is leaking and the footwell is flooded. Before i had the car the window was changed and membrane was never put bk properly and needs replacing, I'm hunting for new membranes atm. Test it by having the door open then put a hose on the window if its the same as mine water will run out of the bottom of the door card
Ok cheers i'll try that. I do suspect that the seal is leaking now though. It only leaks when the passenger side is pointing uphill
