6N2 De-Wipering..
Figured i am going to finally de-wiper the polo, getting bored of the rear wiper collecting dirt..
Couple of questions:
1: How are people plugging the washer fluid pipe?
2: Are people using the universal glass bung from venom's (Venom Glass Bung) or are they using halfords ones?
Any Recommendations..
Dimz
Edited by don_stavrou
  • Replies 19
  • Views 4.1k
I just used the 25mm one frm Halfords. I just rolled up a small bit of tissue and plugged the fluid pipe then electrical taped over the end. A little primative but you cant see it and just remember not to use the rear washer lol
Alright Dimz
1. Tie a knot in it and stick a screw in the end of it
2. Get the assorted pack of bungs from Halfords
3. Buy some RainX and spray it on your rear window every time you wash your car, it repels rain which will help in the current weather conditions.
Fold a couple of times and cable tie, job done.
Using a blanking grommit from halford, or a DIY type shop should sell them.
Dimz
Hope this helps, Pete
Just disconnect the wire to the rear washer and the stalk won't do anything :)
Figured as much thanks mate..
Alright Dimz
Never thought of using RainX! Indy you genius lol.. Thanks dude appreciate the help!
Dimz
Diamond Thanks Mate..
Is removal pretty straight forward i have ELSA but so much easier just to ask..I figure its rear boot cover off ther just unbolt the wiper from the outside and from the inside then pull off and apart?
Thanks Again
Dimz
Alright Dimz
Dimz
Thanks Again
Dimz
Yeah,
1. Unbolt the wiper from underneath the outside cap, then the wiper should come off. (may need some force)
2. Then you need to remove the wiper motor, unbolt from inside underneath the boot trim.
3. Unplug electric and water, fold and tape/cable tie (or any above) the water off, also tape the electric cable to the inside of boot.
4. Fill in the hold your left with with a blanking grommit.
5. Done.
Pete.
Alright Dimz
Dimz
Thanks Again
Dimz
Yeah,
5. Done.
Pete.
Wiked thanks dude going to go halfrauds in a bit.. Is it a 25mm bung i need, i couldn't remember what size the hole was..
Dimz
Dimz
Yeah, it comes in a pack of 3 assorted anyways.
Dimz
How are people fixing them in place because if its what i think it is, it will just plug in and can be pulled off just as easily?
Anyone used sealant or anything like that?
Dimz
Dimz
Dimz
Just pushed in, can get them cheap enough.
Dimz
Dimz
Na i know but its one of these things i am going to do once..lol might carbon vinyl it :p..
Dimz
Thinking of doing this aswell, do you need the wiper to pass the MOT or does it not matter.
bump anyone
bump anyone
If the wiper is fitted it should be working for the MOT according to the testing manual! but I've never seen it tested ever!! so if it's not there I can't see any problem.
Alrite cheers mate.
You dont need it for a MOT, mine has passed without.
then re route the pipe to either the badge or the wing and you got yourself a water pistol for pedestrians :lol:
its great fun, thats where all my mates water went mostly lol
The halfrauds 25mm bungs didnt fit mine probally, i need like a 28mm for it to fit, anyone know where i can get one from.
^^bump^^
