6n2 rear lights
Right new here, I'll try not to embarrass myself.
Got myself a 6n2 16v, it really is a beaut I love it, but the potential is screaming out to me. Cars now tip top (got the dreaded pedal box welded that I read everywhere) so I think I can start with a few mods.
Starting with the exterior I'm a big fan of the standard red rear lights, especially as the car itself is red I think I it looks pretty clean. Only problem is that damn reverse light! What's the best way of getting this done? Can I buy a set of all red lights or is there a way of painting it over or something?
Cheers for any input in advance
  • Views 1.2k
Not sure what your actual issue is mate, are you saying that you don't like the reverse light and you want it to match the other one?
Just buy a european spec one from ebay.de so you'll have two all red rears. You'll have two fog lights instead of one reverse and one fog.
Yeah sorry, basically just want matching all red rear lights
Well I'd buy a left hand side German one then, and they'll both match.
Alternatively you could use some red lacquer light tinting spray and spray them both and you'll acheive a similar result. Only problem you'll have if you do this is that your indicators will flash red.
Nice one mate, I'll check out ebay
If however you want the opposite side to this to be a clear reverse as well then i have a LHD lamp for sale (before you ask, the other is on my car)-
Bit confused here, after a LHD lamp for the left side, to replace the british reverse, is that what you're sellin?
