someone inspire me.
I've been buying and selling/breaking cars for a couple of years now, it wont ever make me rich i know that but it means i dont have to work and get to just do what i want. normally ill buy a car and either use it for a bit and then sell or break it or ill just shift it straight away.
had some gems doing this and had some really good deals but usually i dont care about the car and just get rid once I'm bored(usually a couple of weeks)
i got my polo for 150, took a punt on it as the bodywork is shoddy and it had 1 months mot and 2 months tax.
put it up for the mot and it only failed on tyres and a number plate bulb and had no advisories.
the week after i put it back in with a set of mk1 golf alloys i had nocking about and fixed the number plate light.
ended up with a car with 13 months mot for 200 quid.
original plan was to sort out the bodywork and thrust bearing and sell it on to make a quick couple of hundred.
so far its been nothing but a pain in the ass with it not starting and now it idles high, thrust bearing sounds like its dancing around under the bonnet.
as much as i know i should just break the car I've developed a soft spot for her. I've had a load of mk2 breadvans and will always have a soft spot for them but didnt think i would feel the same about the 6n.
now I'm faced with a dilemma, do i fix her up properly and keep her or do i just break it and go back to what i normally do and go from car to car.
common sense tells me to break it and just buy another one that has no problems but then i do enjoy cars that stress me out, had a few now that I've persisted with and ended up keeping for a while just because i like the feeling of bringin the old girls back to life even tho they were battered and bruised from the previous owners and now hate all car owners.
someone inspire me.
If you really care about this one, then whip that box off and change the bearing...the box is light as a feather so taking it off and on is a piece of piss!
Personally, it has passed the mot on literally F all...so it should tell you its a good one! Personally, i'd only keep it if was of sentimental value. 8-)
Like my polo, i've owned it for approx 6yrs...cant part with it! sure i'v spent a bucket load on it and i could break it no problem and get some cash back but why?! it passes mot's just fine, i take it out in good weather and its fun to drive! 8-)
put the polo to one side and work on it as a project
you can still earn on cars as normal,and get the polo tip top in your leisure
i was thinking this. I've just been out to have a look for the idle issue. soon as i started to take the airbox of i noticed that a small section of pipe that holds a vacuum hose together was missing, took the throttle body of and sprayed the life out of it with carb cleaner and some in the intake just for good measure. also noticed that the throttle cable wasnt sat in the holder properly so sorted that. set the timing again and she sat at 850-900rpm bit lumpy but sat there fine.
took her out for a quick test and she seems to be running fine, revs dont stick anywhere near as bad as before but do stick a little(might be normal as I've not had a 6n?) picks up fine in all gears and goes back to idle at standstill with no juddering or hunting so for now thats that problem fixed, wether or not it works on cold start and warm up is anyones guess.
this is the problem i have with some cars, character gets the better of me and i feel like i need to spend some time on them, whilst i was waiting for her to warm up i sat to one side and had a good stare and i think I've come up with a pretty cool idea of what i could do with her if i do keep her, for now ill keep hush incase she goes but if she stays should be a fun project!
keep it dude!
I'm not a huge fan of a 6n, but if you get rid of it, you'll miss it and n other car will fill it's gap. 'cept maybe a MK2 ;)
