buying a 6n2
hi guys!
so on friday night my driveshaft came lose on my 6n and smashed through my gearbox casing and ruined my gearbox too.
http://www.clubpolo.co.uk/forum/index.php?showtopic=206165
not considering to get a reconditioned gearbox!
as a result looking to go for the 6n2 now.
anything i should keep my eyes pealed for? and what size are the speakers in the doorcards?
cheers - Amit
  • Replies 16
  • Views 1.7k
Speaker size is 17cm, 6.5 inches.
Shame about the 6n :cry:
Keep eyes peeled for gearboxes. Mos go between 50-60k but some last longer. Mine was replaced around 65k. Also check in the boot for the VW spec sticker. If its missing, chances are its been hit in the rear and had a repair. If so, walk away!
thanks man
yeah i know, really gutted i am :tear:
nice 1 bud!
will keep that in mind - cheers!
Also! Mine had the ABS warning light come on. Found it was a dodgy connection under the rear seat. Couple of my mates have had the same problem so if its on it may be as simple as that.
thanks again mate, great help!
what did you are gear box start to feel like when u changed it as mines getting abit stiff sometimes I'm on 63k
my gearbox started to grind when putting it in second, after 2 days in denial i need a new gearbox my uncle looked at it and thankfully said it is the clutch! Doubt any will be rusting so no need to look there i would say mainly clutch and gearbox mate!
i have had 2, temperature sensor goes and then rinses fule happend on both.
Gear box, Gear linkages, clutch, brake light switch (EPC warning light) so quite a lot. Saying that id still have one over a 6n because they dont rust, my one hasnt got a single bit of rust.
Gearboxes are mainly an issue on the gti as it was not reinforced. The main issue with 6n2 boxes is the peddle box as the welds are to weak and split.
i have just bourght a 6n2 with 122,000 on and the abs light kept fashing on and afer putting my sub in and rustling them wires under the rear bench the right has gone off :D what about timing belts and water pumps what mileage they usually done at?
cheers alex
timing belts. every 4 years or i think 70k? (i have a feeling that could be wrong though) Just had mine done at 67k.
Lambda sensors are tempremental on them too.
tbh, there really isnt anything major. great wee cars
my timing belt was done at 84k (10 years) and i couldnt find anything in the service history of it being done any time before that.
Oaft thats leaving it quite late....!
I had the temperature sensor go on mine and the ABS sensor. But both were very cheap and easy fixes
