Full 1600 Polo Set up Carbs/5-speed/4 Branch
Polo/Golf full engine conversion ready to run - £550ono - see spec list in individual price listing below
(only thing missing is igntion module and wiring and coil pack - but will include these if meets £550 sale price)
collection prefered from Macclesfield SK11.
GT CAM Also Available for £50 if required to liven things up a bit more!!
- 1600 AEE 8v Block 90k - £150 - £130
- 1600 AEA 5spd Gearbox - £50 (told similar to G40 box)
- 5Speed Gear Set up - £40 (5speed selector/gear stick/5speed anti roll bar/gear linkage)
- Custom Alloy Carb manifold - £110
- GSX-R600 Bike Carbs (incl silicone hoses)-£50
- 4 Branch Raceland Manifold - £110
- Facet low Pressure Fuel Pump - £35
- Engine Mounts for mk1 - £40
- Starter Motor - £25
- Alternator - £30 - Correct pulleys to run on mk1 alt belt (i.e. no power steering pump)
- Coupe S Dizzy - £30
The carbs would benefit from jetting out to roughly 1.7mm when i put it in for mot it did not even register as running on the sensor - had to rev it up! will be a hell of alot quicker after jetting... takes a bit of cranking to get it started from coldwith small jets but keeping a can of easy start for those cold days will make it fire up on the first crank! If you have any questions let me know...
I also have several polo/golf spares so let me know if you need anything and would accept G40 parts in P/X
Cheers,
Ad
Edited by G40 AD
  • Replies 21
  • Views 893
This mk1 with the engine is was a ridiculous amount of fun! Strong lump and pulled well, as said with bigger jets it will really fly!
only sellin due to far bigger plans fo the lil mk1
Do you have a 1.6 crank sprocket by any chance?
check if an AFH item is the same on vagcat/etka, i have a spare. not sure if pidgeon has, but he should reply back tonight
i can also add this engine flew!
Ok, will do. Dont suppose you have an old style single V crank pulley too do you? Need to swap the AEE one for one compatible with an old style alternator
hmmm I'm very tempted :lol:
How much for a full set up for my GT>
Guessing i will need the ignition stuff, pump, carbs? and i will need to make my own mani?
Would love to make my GT quick for the right money :ninja:
Matt - we'll get that nailed some time soon!
Prankstar - not got any spare alternator pulleys for old style sorry bud...
Grunge, looks as if they are the same, but if you could measure it across then i shall do the same. Total bugger to find these about.
And hopefully my car should fly too once this is done, as its practically the same set up!
drop me a pm some point this evening and i will have a look for you, should also have a v belt pulley for you
post updated - GT Cam also available - not mine but a friends...
Bump Will take 500 for the lot... otherwise will break...
still up for sale... will split...
silicone rubbers, how much :)
Will get that pump to you tommorow mate, will you be in?
should be in before lunch... I had a full section of rubber but need to check what saf used... sure we can sort some out though got loads of bits in the car...
yeh theres enough left over for 4 runners matt, just speak to the pidge re: price and ill pick it up tonight after work
sweet text you in the morning ad :thumbsup:
ill have the carbs tomorrow, drop me a text 07771605314. I'm only in middlewich, cheers. Andi
what bits you after mate?
provisionally sold - pending payment tuesday...
did it sell?
yeah mate! carb set up and one 1600 gone... top post updated.
cheers,
Ad
