HID brightness advice?
I'm looking into buying a hid kit conversion for my 6n2 but not sure on what power to go for. I want that bright blue-ish colour, I've heard it could be 6000k but just want to make sure.
Would be appreciated
  • Replies 35
  • Views 4.8k
I went for 6000K which is usually the default colour temperature as it's a good compromise of brightness and a crisp looking colour. The higher the Kelvin the bluer the light, but also the dimmer the light.
IIRC alot of the standard fit Xenons are 4300 - 5000K.
I'd advise going for 6000K, and in my opinion anything beyond 8000K looks way too blue and you may end up getting hassle from the police for them!
My 8000k kit
thanks for the replies. Yeah think il go for the same ones as you mate and get the 8000k. Look just about right. Cheers for the advice
dirt monkey, any night time pics?
These are my 6000K HIDs at night..
Tris where did you buy your hid's from? I'm looking around at dont have a clue what I'm looking at lol. I know its either 6000k or 8000k i want and I'm pretty sure there h4 bulbs but thats as far as i can get lol
6k through normal lenses like Tris'
8k through projector lenses like Dirt Monkeys
If you want a blue look, don't want to look like taxi and actually want your headlights to do what they are supposed to I would get 6000k...
Personally I would stick between 4300k-6000k.
It's all down to the lumen output (how much light output).. The best light output is between 4100-4300k (hence why most standard HID's from the factory are this temp - Although most modern cars like new range rovers use 5000k as they look better and are pretty close) - as you get a higher temperature (the higher the kelvin as in 6000k, 7000k, 8000k etc) the worse the light output is. So in poor conditions like fog, rain, at dawn and at dusk etc anything above 6000k are rubbish as headlights..
Kelvins to Lumens:
4300k = 3200lm
4300k = 2800lm
4300k = 2400lm
4300k = 2000l
4800k = 3800
5800k = 3300
7000k = 1790lm
7000k = 1390lm
8000k = 1180lm
8000k = 780lm
I went for 5000k for obvious reasons..
Edited by MrP
I got them from here
http://www.hids4u.co.uk/
H4 bulbs on a mk4/6N
H7 on a mk5/6N2
Mine took H7 though as I have FK headlights, which have clear glass, wasn't keen on the idea of running them through standard frosted 6N headlights.
I have a standard 6n, do I have to go for the full conversion kit?
What price could I get for say 6000k HID's for to put in a completely standard 6N, I guess I can't just buy the bulbs?
http://cgi.ebay.co.uk/BI-XENON-HID-CONVERS...54#ht_652wt_911
would that do?
i got standard lens on my 6n is it the h4 hi lol kit i need ?
would that do?
£490.99 :shock:
Guessing that's a mistake lol
Yeah
Kelvins to Lumens:
4300k = 3200lm
4300k = 2800lm
4300k = 2400lm
4300k = 2000l
4800k = 3800
5800k = 3300
7000k = 1790lm
7000k = 1390lm
8000k = 1180lm
8000k = 780lm
You cant actually convert Kelvin to Lumens - Kelvin is a unit of colour temperature, Lumens are a unit of light output. Although there is usually a trade-off between the two, you can't give a conversion table like that, even just buying different brands of, say, 6kK kit would produce a range of light output values.
8K, Foxie's old car
In my opinion, that temp is perfect if you like driving through the day with your xenons on, like I do!
Why do you drive through the day with the HID's on? don't the police pull you over for that?
Why would you get pulled for using lights through the day?
Volvo's use them as standard through the day and most new cars these days have day time running lights.
There's no rule saying you can only put your headlamps on at night.
Lol your not gonna get pulled over and be told, "oi you, turn your lights off it's not dark!"
why do you drive through the day with the HID's on? don't the police pull you over for that?
most bikes have their lights on, just makes you more visible so theirs less chance of anyone pulling out on you
Is it also ok to put the fog lights on aswell? I see lots of cars with the headlights and the fog lights on during the day and night..
Fog lights are illegal if used when it isn't foggy.
£30 fine if your running them when it's not foggy.
Pisses me off when I see people running fogs for no reason, it doesn't look cool at all and it's blinding!
I got a £30 fine in my first car, I had no choice as both headlight bulbs went half way through a journey but the Pig didn't understand that!
8K, Foxie's old car
Me too! Show off the lovely blueyness!
they call them fag lights for a reason
pisses me off to no end, even worse when you get a idiot in front of you with there rear fog on.
if i pass someone with fag lights on when it's clearly not foggy (or even during the day ffs!) they get flashed! 6K HID's + normal Highbeams usually gives them the message.
What i also want to do it wire up 4x 100w spot lights to the front of my car, they'll defo get the message then!
i have a set of 8k H4 main/dipped HID (bulbs, ballasts etc) brand new and still boxed. sold the car they were going on so if anyone's interested make me a sensible offer and they're yours
mack
What head lights are these matey?
